Strange Looking ROM tables, any help??
Old Aug 28, 2008 | 09:26 AM
TouringBubble's Avatar
Scalings have nothing to do with theROM values themselves, so I'm not sure what you're saying. the endian issue has nothing to do with the actual data in the ROM ... only how it is displayed in ECUFlash.
Old Aug 28, 2008 | 11:59 AM
Creamo3's Avatar
You're correct, my terminology that I used was off. Either way I did go to update the endian value and the values in the scrambled map are the same scalings as a stock map.
Old Aug 29, 2008 | 08:55 AM
Creamo3's Avatar
Thanks for your help guys, I finally figured out my mistake. I wasn't aware that there were multiple ROM's out there for 2003, so I wound up plugging in 94170008 and everything is showing up like it should. Sorry for the questions and thanks for your help
Old Aug 29, 2008 | 09:40 AM
Jumperalex's Avatar
now all you need to do is upgrade to 94170015 since it is a better ROM for your car, and all support is being focused on that ROM as far as ecuflash definitions and ROM Patching (e.g. Tephra Patch)
It is a seems swap so long as you copy over your immob code and any modified maps.
Old Aug 29, 2008 | 11:30 AM
Creamo3's Avatar
Just did this, thanks for the heads up. Time to start tinkering
tephra
70
Jul 11, 2024 12:59 AM
Creamo3
99
Feb 23, 2018 03:17 AM
mrfred
Dec 21, 2014 10:13 AM
Creamo3
Jun 1, 2009 10:21 PM
silverghost
Apr 17, 2009 11:21 AM
