EVOScan reading a/f in V?
Help - EVOScan reading LC-1 in volts?
So I've finally made the switch to EVOScan from Mitsulogger mostly just to check its capabilities out but, I'm running into an issue logging my LC-1. The logging keeps spitting the readings out in volts? I've also selected the "AFR map" box which appears like it should, using the equation list of 14.7 * 128/x, calculate the a/f ratio, however, when I log that it only shows 14.7, almost like its not calculating properly?
Any suggestions? I'm using the latest version of EVOScan (2.5).
I don't have a msn messenger account. I would be willing to create one so long as its free. I really would like to get EVOScan straightened out.
Have you had expierence or know of anyone using it on a MAC via Parallels on XP? I've been running ECUFlash, Logworks2 and Mitsulogger that way. Mitsulogger doesn't seem to happy with it though as I keep getting error messages.
AFR MAP is not for wideband data, it's for reading the Fuel Map values from your ROM (ie. target AFR). There should be a separate checkbox for Wideband
As far as logging the wrong values in EvoScan, connect to the LC-1 using LM Programmer and make sure it's calibrated to output lambda in Gasoline scale (14.7:1).
I also need my serial number.
