knock sum count
Old Sep 10, 2008 | 02:58 PM
JohnBradley's Avatar
The car is in limp mode under boost so its all freaked out.
Old Sep 10, 2008 | 03:09 PM
TTP Engineering's Avatar
It sounds like a wiring mess.
Old Sep 10, 2008 | 03:13 PM
I agree. The knock sensor is not working, probably wasnt working 100% beforehand but if its off now the car is in limp mode (as indicated by the P0325).
The P0403 isnt helping the situation and needs resolved.
The 137 is a cat code
...and you have to separate codes for crank sensor issues.
There are alot more problems here than 8-9 counts to be perfectly honest. I would get everything working again first, make sure the knock sensor is hooked up and operating correctly, delete the EGR code via ECUflash encoding or hook the solenoid back up momentarily, and fix the crank sensor.
Then we can help with the knock of 8-9 counts
aaron@englishracing.net
Old Sep 10, 2008 | 03:16 PM
Jeeperjunior's Avatar
^Go with that. You must address those problems asap.
Old Sep 10, 2008 | 03:24 PM
CroatianKid's Avatar
I just got my car tuned by Evan at Vividracing. 0 couts fellas! oh yeah!
Old Sep 10, 2008 | 03:26 PM
It just occurred to me that when the knock sensor is removed from the car it will default to 8-9 counts and lock there.
When chasing a phantom knock car in the past, we had run a number of tests on it. It will drop octane count to 0 automatically and lock the knock counts at the numbers being mentioned when there is no knock sensor signal.
Old Sep 14, 2008 | 01:26 PM
mlancerevo8's Avatar
so i did some more tests and figured out its only goin into limp mode when over 3psi soo meaning when i boost its goin crazy... we were thinking either maf or map but they numbers look right... but barometer is what i couldnt figure out... it droped when i boosted... originally at 99 n boost its at 95 is that right??
Old Oct 17, 2008 | 12:23 PM
D-VO's Avatar
Originally Posted by lemmonhead
tell him knocksums are like punches to the face. you want ZERO if you can. So if he says 8 is ok, then hit him in the face 8 times. its hard or nearly impossible to get 0 everytime. But 1-2 on ocasion is nothing to be alarmed at. 8 at any time is BAD BAD BAD BAD BAD
lmao. That's a good one. Shift knock sucks, low throttle knock sucks, phantom knock sucks, knock decay sucks, and real knock sucks. A quick fix for the first four would be nice.
BeyondLimitsEvo
Cobb AccessPORT
31
Oct 28, 2014 08:02 AM
90zcrex
Nov 11, 2012 04:40 PM
rodrig.diaz3
Jun 30, 2008 10:13 AM
jrsimon27
May 3, 2007 11:01 PM
tkklemann
Apr 28, 2007 05:52 AM
