ECUFlash 1.38 cable fix.
Old Jun 30, 2009, 05:58 AM
  #31
Jeff_Jeske's Avatar
I'm still using 1.30 but would also like to upgrade. I suppose I could try 1.38 but it would be nice to go to the latest and greatest if they work with the hack.
Old Jul 1, 2009, 09:16 PM
  #32
EVIL_EV0's Avatar
anyone?
Old Jul 3, 2009, 09:01 AM
  #33
acidikjuice's Avatar
Question
I have the same issue, so here is what i do: I use the latest version of ECUFlash to open my ROM and edit the data using the latest XML, and then switch to the old 1.29 ECUFlash to read and write data.
I haven't noticed a problem using this method, I don't use 1.29 to edit anything, and all the changes I make in 1.4x seem to write fine, even bobbelbits (or whatever they are called).
Its a small pain in the *** to switch back and forth. You need to make sure to name the install directories differently to keep the copies seperated.
Maybe i'll try this hack later. Good Luck!
Old Sep 24, 2009, 05:00 PM
  #34
colby's Avatar
Originally Posted by cmj
I emailed a few times last year and never got a response. He has never answered the multiple post on openecu.org about it either. I'm still using v1.29.
If you are having an issue such as this with your cable, you need to contact us at support@tactrix.com and we can fix the problem for you.
Colby
Old Sep 28, 2009, 04:05 PM
  #35
TGC_QS's Avatar
i have a similar problem
ive tried ecuflash version 1.28, 1.29a , 1.45
i have a brand new 1.3u cable from limitless.nz ( unless they shipped me an old model and i need to modify it
heres the log
[00:08:08.953] Version 1.28.716
[00:08:08.953] 8 memory models read.
[00:08:09.218] 71 ROM metadata models read.
[00:08:09.218] checksum module "subarudbw" loaded.
[00:08:09.218] flashing tool "wrx02" loaded.
[00:08:09.218] flashing tool "wrx04" loaded.
[00:08:09.218] flashing tool "sti04" loaded.
[00:08:09.218] flashing tool "sti05" loaded.
[00:08:09.218] flashing tool "mitsukernel" loaded.
[00:08:09.218] flashing tool "mitsukernelocp" loaded.
[00:08:09.218] flashing tool "mitsubootloader" loaded.
[00:08:52.281] sending init sequence 1 (0001)
[00:09:04.578] sending init sequence 1 (0001)
[00:09:19.953] sending init sequence 1 (0001)
it keeps opening a window and saying error see log for details
could it be a bad ground or wiring ? bad obd2 port "?
i tried the Ecu unlocker , version 1.1 , didnt work
the cable is properly installed and key is at on when i press the ok button on READ FROM ECU
i read on another thread it might be a bad cable ?
any ideas plz ?
silver_evo
Apr 2, 2009 09:40 PM
CNano8
Jan 24, 2009 11:58 PM
fevo
Feb 8, 2006 02:10 PM
vegasboy301
Dec 12, 2005 06:30 AM
snoop
Apr 12, 2005 10:26 AM
Quick Reply: ECUFlash 1.38 cable fix.
