Evo Scan 2.5 Issue suddenly
Old Sep 13, 2008 | 02:20 PM
Evo8Emperor's Avatar
When I first upgraded to 2.5 everything was fine and it worked great. Now all of a sudden everytime I try and log a run or even at idle my connection drops and it says cant connect to ecu after it already connected.
Ive tried looking through evo scan to see if there was something i did but i havent touched anything. I can connect to scan tech so i know my cable and usb are good. Not sure where else to look. I was going to re download but I cant find the .exe file.
Anyone have any idea's ?
Thanks guys
Old Sep 13, 2008 | 02:24 PM
valvetap's Avatar
Atleast you got yours to work. I have downloaded 2.5. I previously had 2.1 I never got the 2.5 to work even with downloading all the necessary programs.
Old Sep 13, 2008 | 04:23 PM
tephra's Avatar
i havn't had any problems.
maybe time to reinstall the ecuflash driver?
Old Sep 13, 2008 | 04:34 PM
I have looked through the ecu flash folder and I cant really find anything I saw that would be useful. Im want to re-install it but i cant find the .exe file.
Old Sep 13, 2008 | 05:41 PM
WRC-LVR's Avatar
No issues here. I have Evoscan 2.5 and Vista premium on my laptop. I use an older Tactrix cable 1.3 ~ 2 years old. Drivers for the cable are the ver 2.0 which i updated to about 6-8 months. Mitsu ogger also works fine as does the Scantech OBD2 software which I use to reset any codes ( had one issue for a corrupted flash..cable got pulled during a flash :-( )
Evoscan 2.5 installed fine no issues, runs fine including the SAS disable mode for setting the BISS idle correctly.
My friend Greg had an issue with Evoscan 2.5, could not get it to work with his cable ( Tactrix )which worked perfectly fine just before on Evoscan 2.1. We swapped in my cable and bingo it worked just fine ( no we did not install any drivers )
One thing I dont like is the fact you dont seem to be able to see what rpm you are running while in SAS disable mode so no help .. you cant see the rpm and which way to go. Factory guages are inadequate for this.
Milburn
Old Sep 13, 2008 | 05:53 PM
oldevodude's Avatar
over on aktivematrix or ECUflash site (can't remember which) there is a download called "proper tactrix drivers" this should do the trick. Some cables do not work with the newer tactrix drivers. You might want to go to device manager in windows and uninstall existing tactrix drivers reboot and install new tactrix drivers. I have used both Evoscan and ecuflash sourced cables and the older evoscan cables definitely like the older tactrix drivers. Another idea is to simply install the tactrix drivers that came with ecuflash 1.29a When installing newer versions of Evo software just say no or cancel when the driver installation comes. If you are running Vista then it could be all sorts of other things as well.
If after looking you can't find what you are looking for PM me your email addy and I will send. try to look first though as overall I'm lazy
Good Luck
Old Sep 13, 2008 | 06:38 PM
Thank you very much. Ill try them both and I think I should be fine. But thank you for the help. If not Ill shoot you a pm.
Thanks again. Ill have to try it in the morning anyway to tired to go outside also.
Old Sep 13, 2008 | 06:52 PM
Jack_of_Trades's Avatar
Make sure any unneccessary boxes are checked for wideband stuff. Try logging just your timing or something to see if it stays connected. Also make sure the correct "mitsubishi" box is checked at the top.
Old Sep 14, 2008 | 07:41 AM
Thanks Jamie. I downloaded the new ecu flash 1.38 last night thinking the new drivers may help but they didnt. Im still having the same problems. I can connect to scan tech no problem but when i go to log the car it connects then disconnects saying its not reading ecu.
Now when i start up evo scan is says "root menu" missing. Any ideas ? im trying to re downloaded evo scan now and see what it does. I dont know why its not working all of a sudden I didnt have a problem before just now.
Old Sep 30, 2008 | 11:52 PM
D-VO's Avatar
So were you able to get it to work after reinstalling evoscan? Did you change or install anything? Any fuses blown? Does ecuflash work?
lolazour
Oct 9, 2016 03:53 PM
denlin68
Apr 28, 2016 10:21 PM
9!'clipseDOHC
Jun 11, 2015 06:47 PM
JDM.Spec
Feb 9, 2014 12:34 AM
kromix
Jul 13, 2003 07:58 AM
