Ignition Retard Vs. Air Temp
Mrfred, other disassembly gurus...
Have you guys seen this table yet? Mrfred can you trace it and see if it does what it looks like it does?
retards timing based on intake temp, I know the DSM's did this..
Here is the code for 88590015
Code:
<table name="Ignition Retard vs Air Temp" category="Timing" address="3c8e" type="2D" level="2" scaling="Enrich"> <table name="Air Temp" address="714a" type="X Axis" elements="8" scaling="Temp"/> </table>
Well let's see if it's correct.
It is showing -1* at 100F intake temps, which I personally have never logged. I regulary see 100F intake temps in the dyno room.
Mattjin mentioned this table in his thread regarding a bunch of new tables he'd found recently.
rom
I added the definition that you listed above to my rom 88590015 but when I bring up the table in ecuflash I don't see any numbers in the table. There are Xs in every cell probably indicating to me that the definition is not correct.
Code:
<scaling name="Enrich" units="deg" toexpr="x-128" frexpr="x+128" format="%.0f" min="-128" max="128" inc="1" storagetype="uint8" endian="big"/>
Good stuff.
