Boost control using EcuFlash and stock pills
Old Dec 14, 2012 | 12:40 AM
WikdEvo's Avatar
If you are using an aftermarket boost controller then just run all new lines. Are you tuning your fuel maps when changing boost????
Old Dec 15, 2012 | 12:18 AM
stunt2's Avatar
yes and yes
I've run all new lines but it's just that old style solenoid, that can't cope boost above 23 psi from the factory
thought some restriction in solenoid inlet or outlet hose would give it a room for more boost at same duty cycle. am I thinking wrong ?
Old Dec 15, 2012 | 01:59 AM
WikdEvo's Avatar
If you're using an aftermarket bcs then you might want to check with the manufacturer on how it reacts with pills. But, generally, yes a pill will allow higher boost.
Old Dec 15, 2012 | 10:24 AM
stunt2's Avatar
where to put it, J pipe to ebc solenoid or ebc solenoid to actuator hose ?
where does it need restriction
Old Dec 15, 2012 | 11:05 AM
Lancer_Evo_8's Avatar
So if i understand right. When i want to install a aftermarkt Solenoid (like Grimmspeed or GM) or a Boostcontroller (like Apexi or HKS) i have to remove the pill/pills?
But where i can finde this pills? And which i have to remove?
So i have to take it out the Pills or i can let it like OEM when i want to install a grimmspeed Solenoid??
Old Dec 15, 2012 | 11:08 AM
Jorge T's Avatar
Just use the new lines that come with the 3 port. ditch the stock lines with pills.
Old Dec 15, 2012 | 06:21 PM
WikdEvo's Avatar
I would say in between the compressor cover and solenoid.
Kracka
May 18, 2020 09:45 AM
razorlab
May 16, 2008 10:22 AM
Zeus
South Region
Nov 15, 2007 02:13 AM
roger smith
Sep 18, 2007 04:03 PM
KK
Auto Dealer Classifieds
Sep 3, 2003 05:28 AM
