new to TehpraMOD
Old Sep 26, 2008 | 04:14 PM
fahdc's Avatar
new to TehpraMOD
hi,
i am new to tephramod and would appreciate some expert help - i have got 2 cars being modded currently EVO 7 and 8 JDM Spec Manuals. i have used 2 different tephraROMs to flash both cars - on both i did the following
  • i was able to flash ROM on ECU
  • was able to get stationary / rev limit etc working
  • not able to NLTS ( need a guide on how to setup )
  • not able to use antilag ( need a guide on how to setup )
  • Is it possible to increase boost via ECU FlaSH?
  • want to know exact xml and ROM file posted for the above cars.
i would appreciate if someone can help guide me with some DIY guides for the above - what settings and what map edits should i play with - i would appreciate all help that you experts can give -
regards and thanks in advance
F
Old Sep 26, 2008 | 06:50 PM
tephra's Avatar
Antilag isn't part of TephraMOD - unless you have the SAS hardware dont bother.
NLTS - have you got a top clutch switch? what happens when you do the standstill test?
increasing boost - nah not possible ...lol.... try searching
XML - try posting up ROMID's.. and then u might get help...
Old Sep 26, 2008 | 10:04 PM
fahdc's Avatar
tephra - first of all - thanks for the your awesomeness , your simply legen .... wait for it ...dary!!!
  • for antilag - pardon my noobness what is SAS hardware.
  • NLTS- assuming i have stationnary working and my car does not start if i dont press clutch - i do have a button.... also how do you do the standstill test - what configurations are required - i dont know the values etc. sorry for my noobness here i really wnt this feature to work in my cars - please help.
  • XML -- i am still waiting for someone to tell em what ROM ID should i use for EVO 8 JDM Manual 2003 so i can download tephramod ROM for evo8. for EVO 7 i am using 90550001.
  • so what the turbo mapping actually do in the mod?
thanks in advance and looking forward for your help.
Old Sep 27, 2008 | 11:32 PM
fahdc's Avatar
tephra ???
please help
Old Sep 28, 2008 | 04:59 AM
tephra's Avatar
Secondary Air System
NLTS standstill = 0speed, 0load, 20% tps - sitt in garage and rev car, push on clutch... if its working the rpm's will drop. top clutch switch is different to bottom clutch switch which controls starting
You need to tell us what ROMID your car has, download it and then use address 0xF52 for ROMID
turbo mapping???
Old Sep 28, 2008 | 07:03 AM
fahdc's Avatar
thanks teph,
i am using 90550001 from the other thread-the stationary and all are working fine - i would need to check top clutch switch ..
with the settings to test NLTS standstill - i rev the car and push on clutch - what will happen? i mean RPM will drop to what?
Old Sep 28, 2008 | 07:05 AM
tephra's Avatar
whatever you configure the rpm drop to..
ie rpm drop of 1500, and you clutch in at 3000rpm, means you will drop to 1500 and then sit on 1500 until you release the clutch....
garage test = car in neutral
Old Sep 28, 2008 | 07:12 AM
sub7's Avatar
Evo7 doesn't have clutch switch unless you put in one yourself, so you basically you can't have NTLS without clutch switch.
I guesss the wikipedia have most of the answer you need.
http://evoecu.logic.net/wiki/Main_Page
senate6268
Lancer Engine Management / Tuning Forums
91
Dec 26, 2022 12:20 AM
senate6268
703
Dec 5, 2022 02:44 AM
mr.k
Jul 26, 2017 02:36 PM
AWDTFTW
Apr 3, 2016 04:39 AM
Hiboost
15
Jan 10, 2016 10:15 PM
