Just filled up with e85 and...my car is not happy :(
Old Oct 1, 2008 | 09:31 AM
  #46
RazorLab's Avatar
Originally Posted by Resi
idle is 14v, cruise is between 13.75-14v.
If I were to increase the latency, wouldnt that cause the idle trim to go further into the negative, and the cruise to move closer to 0?
Increasing latency is adding fuel at that voltage, decreasing is taking away.
idle -11.5, cruise +12.65
To my understanding, this should not be possible unless something is physically wrong with the fuel system. I am now thinking I either have a clogged injector or fuel pump filter is clogged or is not in the correct position which is impeding fuel flow. Does this seem feasable?
It is possible and one of the joys of scaling injectors. It sounds like your injectors weren't scaled properly on 91 and now that you put E85 in, it's really compounding the issue.
Since your idle trim is negative, take some latency away. Since the cruise trim is positive, take some scaling away.
Old Oct 3, 2008 | 09:15 AM
  #47
fostytou's Avatar
EvoM Community Team
1) fill the tank with e85, and 2) decrease the scaling by 30% and the car would fire up and she'd be ready to rock 29psi all day long. I should have known, life is never THAT simple
Make sure you add some fuel in the upper part of your table also. Even after smoothing in ~10% (I think, based on Jack's post in another thread) extra fuel in the upper cells I was running a little lean
(thats in regards to things not feeling right past ~15psi)
Old Oct 4, 2008 | 11:01 AM
  #48
Resi's Avatar
Good point, never was able to log my afrs on e85 since my wb broke. Got that fixed now, and fixed an exhaust leak as well.
Unfortunately my work schedule is chaotic for the time being, so it will be a few weeks till i get to play with my fuel trims again. I am back on my 91 tune and injector scalings, and everything is fine...its nice to be able to boost again, driving a prancer sucks
Once I find some free time, i will do some tests on 91 with the latencies i was using with e85 and see if i can get them leveled out.
BTW, I have 4.5gal of e85 in the garage in a VP jug, how long will I be able to store it without having to worry about water absorbtion/contamination?
Old Oct 10, 2008 | 12:35 PM
  #49
agron25's Avatar
you have to high octane ignition and high octane fuel map very low
Old Oct 10, 2008 | 12:42 PM
  #50
agron25's Avatar
evoIX
my config E85
full dacata 76
AVCR
walbroo
blow off agency power
turbo elbow megan racing
injector 1000cc PTE scaling 680cc
my AFR ,lambda 0.84 wot
nj1266
Jan 25, 2026 01:43 AM
cplillges
May 25, 2017 04:33 AM
clockworktoy
Dec 11, 2011 12:20 AM
jcsbanks
Jun 9, 2011 11:45 AM
