MAF or MAP sensor ???
Old Oct 1, 2008 | 12:48 PM
zedevo's Avatar
Im running on ECUTEK with FPGreen, cam's etc ... What would u recomend me to stay on MAF or to switch to MAP Sensor ?
My tuner would like to DELETE the MAF what do u think ????
Any advice ASAP
thx a lot ...
Old Oct 1, 2008 | 06:55 PM
tephra's Avatar
for the average joe public running stock ECU without a MAF is not possible - yet...
unless you are pushing 300kw+ then you don't need to worry about removing the MAF..
Old Oct 1, 2008 | 08:11 PM
JohnBradley's Avatar
MAP sensors on the stock ECU tend to be problematic. Even with an auxillary ECU making the calculations (like I am using) and the stock ECU making all the control changes. You can run into odd lean spots, tip in issues, cruise issues. How does your tuner plan to implement this switch to just a MAP sensor? Does he mean a full standalone?
Old Oct 1, 2008 | 11:09 PM
zedevo's Avatar
so with the MAP no way to have problems ???...
Old Oct 1, 2008 | 11:12 PM
zedevo's Avatar
No ... STOCK ECU ... i can refuse this idea for sure .. but i dont want to regret my decision ...
Old Oct 2, 2008 | 12:11 AM
Jack_of_Trades's Avatar
Its not even fully possible yet with the stock ECU. There are maybe 2 people working on this right now but there isn't anything available to everyone just yet. Like Tephra said, for most peoples power levels, you don't need to change anything. People are making over 500whp on the stock ECU and MAF with no issues.
Old Oct 4, 2008 | 08:36 AM
zedevo's Avatar
So ill stick on my MAF, thx a lot guys ...
PEACE ,
Old Oct 6, 2008 | 08:33 AM
C6C6CH3vo's Avatar
The problem with the maf/ecu is that all the programmed settings and filters were calibrated and tuned for stock everything. All the way down to the snorkle and airfilter which have a significant effect BTW.
Even though most of the offset obtained with mods can be fixed with hundreds of datalogs, flashes, and experimenting and failures, it boils down to getting an airflow hz signal respective to volume at all volumes, pressures and temperatures, and loads. On the otherhand this does provide you with somewhat effective means of afr control, just a very roundabout way requiring constant logging and tweaking.
I still run maf but I bet you'll be better off with density method when tuning cam timing, different cams, or head mods.
Old Oct 6, 2008 | 10:41 AM
zedevo's Avatar
Old Oct 6, 2008 | 01:09 PM
C6C6CH3vo's Avatar
uuurrrrp,
thanks
upcom'n_meknk
Lancer Troubleshooting
May 15, 2017 12:31 PM
maxspeed96ct
Northeast Region
Aug 22, 2016 11:08 AM
FRESH.I.AM
20
Jul 15, 2016 07:12 PM
need_an_evo
Mar 29, 2016 09:14 AM
dEdiYT11
12
Sep 3, 2004 08:18 PM
