Ignition Retard Limit
Old Jul 31, 2009 | 05:42 AM
  #46
Oettinger's Avatar
I change also this offset, 0x173f to 255 but... only -10º, not work 0x173f and 0x173e to 255, tephra any solution??
Old Jul 31, 2009 | 06:38 AM
  #47
Mellon Racing's Avatar
Originally Posted by Oettinger
With my ecu 96530006, i change adress 0x173e to 230 and no gain in log to -15 or -17 degress, not work this patch for evo 8, other solution please!! Only -10 i need -17 minimun.
what do you need -17 degrees of timing for?
Old Jul 31, 2009 | 09:36 AM
  #48
JohnBradley's Avatar
True Antilag. It will be generally in the range of 15-25* retard to ignite the fuel in the exhaust manifold. On a Euro car doesnt it already have the SAS factory system?
Old Jul 31, 2009 | 06:49 PM
  #49
Oettinger's Avatar
Hello Mellon! more time without speak with you jeje all good friend?? Best Regards this spanish boy jeje
Yes is for real ALS, minimun is -17º, but ecu is only to -10º
In europe, SAS only un RS version, GSR version without SAS system. With throttle kicker is the solution and retarding to -17º o r -20º, this ecu is very bad, this limitation is ugly.
Old Aug 1, 2009 | 07:47 AM
  #50
ok, I figured that's what you guys were getting at but didn't see it mentioned or just missed the point.
Old Aug 1, 2009 | 10:45 AM
  #51
Oettinger's Avatar
Any solution for delimiting this restriction-ignition-retarding this ecu??
Old Aug 7, 2009 | 05:58 PM
  #52
Biggy VIII's Avatar
bump
Old Oct 1, 2009 | 07:13 PM
  #53
Oettinger's Avatar
Tephra any info for this problem with retarding in ecu more -10º? Thanks!
Old Oct 1, 2009 | 08:50 PM
  #54
Ceddy's Avatar
Originally Posted by tephra
Hi Guys,
While looking for this knock stuff I came across the Ignition Retard limit in the ROM.
88590015 and 88580013 (9's???): 0x133e
96530006 and 94170015 (8's???): 0x173e
2 bytes, so uint16 scaling.
Now it defaults to 203 (or 0xCB), I found that by increasing it to 220 I was able to run -15* as opposed to the previous limit of -10*.
Now whoever disasm'd this ROM (Bez???) already found this, so I don't want to take any credit for it
Also I don't know the proper scaling yet, but if anyone figures it out let me know
The scaling in earlier ecus is: x * 90/256 degrees, referenced to the CAS pulse rising edge (75.77 degrees BTDC)
0xCB(#203) * 90/256 = 71.37 - 75.77 = -4.4 degrees
That gives a limit of -5 degrees not -10, I'm not sure if you have to factor in the 5 degrees of base timing, that could give the expected -10 degrees.
Edit:
This is incorrect scaling, see post 60.
Old Oct 2, 2009 | 04:50 PM
  #55
Oettinger's Avatar
Translate for humans please no for programers jejeje
Old Oct 3, 2009 | 05:03 PM
  #56
Based on that math isnt less more? Or am I looking at it upside down?
Old Oct 3, 2009 | 05:22 PM
  #57
Ceddy's Avatar
See post 60.
Old Oct 3, 2009 | 05:38 PM
  #58
I get it now, thanks Ceddy.
Old Oct 3, 2009 | 07:25 PM
  #59
Biggy VIII's Avatar
Originally Posted by Ceddy
Its referenced to -81 degrees. Since its negative, its kinda backwards of what you would think. Less would be more retard.
000 = -81 degrees (rounded)
010 = -77
050 = -63
100 = -46
200 = -11
250 = 7
300 = 24
350 = 42
Each unit is about 1/3 degree.
Setting the limit to ~180 actually limits timing retard to -5 degrees. Setting it to 203 or more allow -10 degrees. Evo8 EDM 96530706.
So this logic is incorrect.
Old Oct 3, 2009 | 08:17 PM
  #60
Ceddy's Avatar
Good looking out Biggy.
Thats an error on my part. There are like 10 different scalings for Ign Timing the ecu uses. I was looking at the wrong one.
People called this Tim61 in previous ecus.
x = 256 * (61 - degAdv) / 90
degAdv = 61 - (x * 90 / 256)
This would make:
220 = -16.34 degrees
203 = -10.37 degrees
188 = -5.09 degrees
173 = 0.18 degrees
If someone with an Evo ecu could confirm this scaling correct, it would be helpful.
