my LC1 is pissing me off!
Old Oct 24, 2008 | 08:08 PM
draconx's Avatar
hey guys my LC1 is making me really mad. just recently i got the ' error 8 ' code so i figured if i recalibrated the sensor it would work fine. so i did (took the whole thing out) and it worked fine for the first log. then it started doin the error 8 code again.
now when i fire it up (log works or evoscan) the sensor doesnt connect or just stays on '0'. its qutie annoying and i've been reading about some of the other users have problems with their LC1's and their RMA's and well yea, im hoping that not the case.
anyway have any ideas?
LC1 (w/o guage, had it for about over a year now and just now starting to act up)
firmware: 1.10
sensor is brand new. (my other one broke so i just replaced this one like about 2 months ago)
Old Oct 24, 2008 | 10:55 PM
oldevodude's Avatar
did you try running it in logwaorks? Is it set for Gasoline? Maybe you should check your grounds.
Old Oct 25, 2008 | 12:36 AM
draconx's Avatar
grounds are good. and yes i tried those both. still nothing
Old Oct 25, 2008 | 01:45 AM
oldevodude's Avatar
has it ever worked with new sensor? maybe bad sensor?
Old Oct 25, 2008 | 03:50 AM
kkarim's Avatar
try updating the firmware, resetting calibration in logworks, and doing free air calibration.
see what that does.
Old Oct 25, 2008 | 07:18 AM
draconx's Avatar
yea i tried all that except for the firmware. i have the latest one though so how would i upgrade it?
Old Oct 25, 2008 | 07:25 AM
Boltz.'s Avatar
FCOTM Winner
My LC1 was the biggest piece of garbage I ever put on my evo.
Old Oct 25, 2008 | 07:48 AM
nothere's Avatar
Innovate suffers from two big thorns
1, the need for a well thought out instillation with perfect execution,
the ability to read and comprehend instructions, and follow them (what male is good at that?)
2, they had a batch of units that were faulty.
So yes, it takes a person with a hobbiest mentality to get one working. Or at least the perception that it won't work unless you do everything just so. I really understand the frustration of those who got (1) right but got a number 2 unit.
If you get beyond the two issues above, it is fine piece of equipment far exceeding the needs and uses we put it through.*
*in my limited experience
Old Oct 25, 2008 | 08:24 AM
logic's Avatar
Just re-install the most recent firmware, as if you were upgrading. This resolved a problem I had where the LC-1 got itself into a very inconsistent state for me.
That being said, it was user error: I had borrowed power from the cigarette lighter, and when I had my laptop power being drawn from there, the LC-1 had a VERY bad day. You really need clean, consistent power and ground for the LC-1 to operate as expected.
Old Oct 25, 2008 | 08:27 AM
dsm25psi's Avatar
i hate my LC1 taking all the **** off and getting my self aem.
Old Oct 25, 2008 | 01:41 PM
todd6027's Avatar
have to say never had a problem with innovate lc1 , either of them .
Old Oct 25, 2008 | 02:58 PM
draconx's Avatar
alright ill try what logic said by redoing the firmware. hopefully that'll work. i've had this for over a year now and up until now its been awesome...
hopefully it'll fix it. we'll see
Old Oct 25, 2008 | 04:36 PM
draconx's Avatar
upgraded it and still doesnt work (think its a connection error. ill check it out later and get back to you guys)
Old Oct 25, 2008 | 05:24 PM
silver_evo's Avatar
Mine works just fine! The lc-1 module is by the power steering tank, the wires run thru the fire wall passenger side, all the connections are made to the ecu main harness. All connections are soldered. There is a good chassis ground their too. Has worked fine for almost a year. I lost cal data once b/c un-plugging data connection while data logging. but a free-air restored it. Have had a few error codes if i dont let the warm-up go 100% It will stop at 99% for about 30 seconds, but once my gauge starts reading like 20.0AFR then i will start the engine. NOT BEFORE! I dunno, i think the lc-1 is the best/cheapest solution around, the 2 programmable analog outs are a dream. I can run a gauge and simulate the narrowband sensor. (and change the narrow band heh.. I cruse at ~15.8 afr.. MPG^^^)
Old Oct 25, 2008 | 07:16 PM
C6C6CH3vo's Avatar
Had LC1 for 2 years with no E8, then it died during a firmware load.
Try a much longer heater cal.
The E8 is just safety feature to keep the sensor from overheating which can be false triggered at times from excessive fuel
