I just Screwed up....HELP!
Immob code is 4 digit but most start with 0 so if you plug a number from 0001 to 0999 you will eventually get it; maybe. Wait, this will take forever...Just remove it then like what the others are saying...:
Once again, razor to the rescue. OP, you better buy this guy a beer, he just helped you keep your friend.
If it was 4 digit # it could go to 9999 but actually its a hex number anyway so with that it could also contain letters ranging from A-F (In easy to understand terms)
Can someone give me a quick walk through on this
add the following to the rom definitions file: <table name="(periphery 0)" category="Misc" address="faa" type="1D" level="1" scaling="Hex16"/>
in ECU flash you should see a table named (periphery 0) in the Misc section.
Change the value to 0x56D2 from 56DA
Not for anything though if you are having trouble understand bryans post you may want to reconsider tuning someone elses car until you have a better grasp on what you could be affecting.
BTW if you decide to disable the immobilzer I'd appreciate it if you posted the VIN and location of the vehicle
