EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
With Travmans help, I found a debug statement used when upgrading for vista64bit in the v2.6 beta6, the speed jumped from 40samples per second to over 100 samples/sec again
oops.
With Travmans help, I have found the wideband comport code is not compatable with vista 64bit edition. I am going to implement a new GPS and Serial Comport code base that will be more widely compatable.
oops.
Please advise it would be nice to have the improved map tracing with the higher resolution otherwise I would just continue on the older versions.
Thanks In Advance
ESv2.6beta6 is looking well. Unfortunately I am coming up with this error:
Error: Object reference not set to an instance of an object.
With AEM UEGO / Vista. I have searched, and it seems to be a common problem with no answer. Is this currently being worked on or is there a fix? With WD not checked, evoscan reads fine. Doh!
yes many widebands were broken with the advent of the multithreading, multithreading is very complex. I will piece it all back together, hopefully soon. I am going to use a new serial.IO programming too, the free one I downloaded has too many issues on Vista. I have a new one that works great for GPS NMEA serials and perfect for Widebands, I'm putting it together at the moment.
Let me know if you need connected again to my laptop for any testing or trial/error stuff for the wideband connection.....
yes GPS will work, but you can ask me to disable it before sending it to you if you want. Its just a matter of removing it from the SDcard, or renaming the directory on the SDCard.
