EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
Old Dec 12, 2008 | 11:11 PM
  #151
oldevodude's Avatar
Originally Posted by evo4mad
That sucks, I am building a new website, I'll benchmark all the versions, and make them all available to download (a new registered users section) If you are really concerned about speed of logging you can revert back to a faster version. but to be honest the core logging system should still be running very fast as the architecture is still the same. I'll look into it.
I am fully registered and looking forward to getting it worked out. For now serious logging done in good old .99 ver. with jdm map,2byte and lc1 02. I really like the map tracing of the latest version but I only get log data very .3 seconds if lucky and usually every .5 seconds
Thanks Hamish
Old Dec 12, 2008 | 11:20 PM
  #152
evo4mad's Avatar
do you have wireless laptop and msn messenger? add me hamish_ahern@hotmail.com I would like to connect to your pc to see for myself, because EvoScan should be running at least 100+ samples per second. thanks.
Old Dec 12, 2008 | 11:58 PM
  #153
funks's Avatar
Hamish - how about converting a NAVIGON 5100 (Windows CE 5), it's fully hackable.. Has 256Megs onboard too.
SD Card - Checked! (Comes with a 2Gig card which has the WinCE 5 OS, and the Software) - it's easy to add WinCE software to it by just copying it to the SD card.
3.5" Touch Screen - Checked!
Built in GPS w/ Software - Checked! (SirfSTAR III).
USB Port! - Checked. (although a driver might be needed to make it a host based interface).
You should think making your software work with the Navigon devices instead, dealing with hardware will just cause you more pain IMHO..
The Navigon 2100 can be had for around 99$ too (although it only has 64MB), the same 2 GIG SD card though.
Old Dec 13, 2008 | 12:27 AM
  #154
evo4mad's Avatar
nah its too expensive: it says you save $99.99, its actually NAVIGON 8100T GPS NAVIGATOR MSRP $599.99 or GPS NAVIGATOR 2100max MSRP $249.99 yeah my factory can make the quiet cheap in quantities of 1000+
Yep, it took me 300hours to make a usb driver, and another 300 hours to program the EvoScan logging and another 300 hours to program the reflashing software, the time isn't in the hardware. The time is taking all the ideas and code thats in my head into visual studio 2008, I am so productive I even dream about the code some nights, and then program it up the next day. lol
Old Dec 13, 2008 | 01:13 AM
  #155
fixem2's Avatar
^^^maybe productive but borderline obsessive!! Ha ha!
Old Dec 14, 2008 | 02:53 PM
  #156
burgers22's Avatar
maybe the map editor could use things like the iPhone, with the spinning wheel, to select a new value like playing russian roulette with your evo lol, what timing am I going set today, lol.
Simple arrows to select the cell, a select button, and arrows again to change the value, and a save, return button. Never had an iphone
MB
Old Dec 14, 2008 | 11:05 PM
  #157
evo4mad's Avatar
thats a good idea, ok I'll do it
Old Dec 14, 2008 | 11:35 PM
  #158
fixem2's Avatar
Evo4mad, at the beginning is the reflash software only have the capability to load a ROM to the ECU?
Old Dec 14, 2008 | 11:46 PM
  #159
Jobi's Avatar
Am I the only one to experience the following problem:
Here is what Evoscan tells me when I try to playback a log file:
"Input string was not in a correct format.Couldn't store <27.843137254902> in TPS Column. Expected type is doubled."
I just don't see what's the problem...
Oh, BTW, TPS value reading goes from somewhat 12% to...100%. And I can only open my log files in graph mode (vs time)...
Someone could help please?
Thx!
Old Dec 15, 2008 | 12:14 AM
  #160
evo4mad's Avatar
Jobi, please log a support call for something like that. i'll take a look at the calculation, it should always round it to 5 decimal places, and have no problem. you using v2.6 beta6 from the first post?
yes 12%-100% is the way mitsubishi engineering designed it.
Old Dec 15, 2008 | 12:19 AM
  #161
evo4mad's Avatar
Currently it does the following:
Evo7/8 Read Rom + Write Rom + Test Write Rom + Compare ROM
I am hoping to do "Edit Rom maps" based on the post above. with some up/down arrows on the touchscreen, it might be for the second release, because the Gauges are more important, i'll see how I get on over the holidays.
Evo9 and subaru reflashing support to follow early next year. Evo10 reflashing will be supported once tactrix gets it working on the openport 2.0 cables.
Old Dec 15, 2008 | 12:20 AM
  #162
evo4mad's Avatar
I just got an EvoX ecu posted to me on loan, so I am working on EvoX datalogging today.
Old Dec 15, 2008 | 06:32 AM
  #163
Mellon Racing's Avatar
sweet I have quite a few X customers ready to buy Evoscan as soon as it's supported.
Old Dec 15, 2008 | 07:02 AM
  #164
evo4mad's Avatar
turns out it wasn't even an evo10 EFI ecu, it big L for LEft and big R for Right on it, I'm not sure what ecu it is.
Old Dec 15, 2008 | 07:03 AM
  #165
evo4mad's Avatar
instead 16x4 and 12x4 pins I expected it, had 2x3 15x4 2x3 15x4
