EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
Old Nov 25, 2008 | 11:49 PM
  #106
evo4mad's Avatar
inserting 14? hmm I don't think I did that.
Old Nov 25, 2008 | 11:50 PM
  #107
evo4mad's Avatar
yes SDCard slot can take 8Gb sd card I think, I've only ever tried up to a 2Gb though. EvoScan and gps software is provided on the sdcard so it can be upgraded. logs will be stored on the sd card.
Old Nov 26, 2008 | 06:33 AM
  #108
mfr122887's Avatar
What is supposed to happen when there are gaps in the data? I'll post a screen shot of what I am seeing.
Old Nov 26, 2008 | 09:35 AM
  #109
fixem2's Avatar
Hamish, what OS is used? SOmeone stated win CE, but I was unaware of Ecuflash running on this platform. How does Ecuflash get installed on the device and upgrade? (Through the SD card?)
Old Nov 26, 2008 | 09:39 AM
  #110
fil78's Avatar
I would suggest to log the same value as the latest valid LC1 data
Old Nov 26, 2008 | 10:55 AM
  #111
fryedchikin's Avatar
There still appears to be an issue with the MapTracer in Beta6. The CSV file shows data is being logged correctly but the MapTracer will not display anything.
I have attached my data.xml and a sample of a log file.
File Type: zip
Old Nov 26, 2008 | 11:31 AM
  #112
mfr122887's Avatar
I am also having this problem. I think it has something to do with logging 1 byte load. If I change the name in the CSV to the standard 2 byte load name, the maptracer works.
Old Nov 26, 2008 | 04:53 PM
  #113
silver9mr's Avatar
anybody have any ideas if and or when the 2.0 tactrix cable works on evoscan 2.6 or is everyone still useing the 1.3 cable cuz i got the 2.0 cable and im dead in the water with it when it comes to logging
Old Nov 26, 2008 | 07:00 PM
  #114
laakness's Avatar
From what I remember during the first usergroup voice chat thing it's a Windows CE device, probably CE.net 5.0 or 6.0. The beauty of the .net framework is you can recompile your code for a different device...don't get me wrong though, I'm sure there was a lot more work in porting it over to CE/Mobile.
Also, the GPS software he is running on it is made by Nav N' Go called iGo or Navigator which is made for CE/WinMobile devices.
Old Nov 26, 2008 | 09:08 PM
  #115
G20's Avatar
G20
maptracer is working for me. I'm using 2-byte load so.
Old Nov 26, 2008 | 10:18 PM
  #116
My data.xml is setup with the option to log several 2 Byte load values in addition to the 1 Byte. My sample log used the 1 Byte, however the problem persists even if any of the 2 Byte values are logged.
It seems like the MapTracer is not correctly reading the data.xml file in order to determine which values are specified as Unit="Load"
Old Nov 27, 2008 | 06:40 AM
  #117
silver9mr's Avatar
any takers on the 2.0 cable working on v2.6?????????
Old Nov 28, 2008 | 03:16 AM
  #118
evo4mad's Avatar
sorry 2.0 is not made by me, but i am looking to support it for you.
of course ecuflash doesn't work on wince. I wrote my own reflashing software.
Old Nov 28, 2008 | 04:45 AM
  #119
joedr's Avatar
EvoM Moderator
Hi Hamish!
A few questions in regards of the GPS.
1. Are we going to be able to edit the gauges or at least to be able to use our own gauges templates on the GPS? I have my own gauges customized to my likes and would like to be able to display them in the GPS.
2. Can we edit the data settings to be displayed in the GPS? I have moved certain MUTs around to support MAT readings, etc.
Old Nov 28, 2008 | 05:07 AM
  #120
tephra's Avatar
YEAH i reckon so, its just evoscan running on a small screen, so you can use a custom data.xml for custom items just like we do now...
