EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
Old Nov 20, 2008 | 07:21 PM
  #76
golruss's Avatar
Originally Posted by lan_evo_mr9
thanks golruss, worked perfect.
Glad I could help.
Old Nov 20, 2008 | 10:07 PM
  #77
G20's Avatar
G20
Hamish,
is it possible to log the wideband signal using the touch screen? Then I can leave the laptop at home. I'm using Zeitronix.
Old Nov 20, 2008 | 10:19 PM
  #78
laakness's Avatar
Originally Posted by G20
Hamish,
We talked about this during the first usergroup meeting and it sounded like the manufacturer would have to do some modifications to make a serial device work. We did discuss that you could follow the thread on wiring one of the wideband outputs to the ECU and log it that way using this device.
Anyone can jump in and correct me if I'm wrong.
Old Nov 20, 2008 | 10:51 PM
  #79
tephra's Avatar
yeah easiest way would be via ECU connection method..
Old Nov 21, 2008 | 03:21 AM
  #80
TeKiZeRo's Avatar
I'm running Vista64 on my laptop and just tried out 2.6. I had this problem with version 2.5 as well, but does anyone know why my coolant temps keep reading -40C? I live in California and I know it doesn't get that cold here.
Old Nov 21, 2008 | 10:44 AM
  #81
evo4mad's Avatar
EvoScan v2.6 beta6 original post updated.
1) Finally fixed Vista64bit .net framework issue.
2) Fixed hotkey bug when custom key didn't contain ctrl - thanks TEphra.
Old Nov 21, 2008 | 10:49 AM
  #82
evo4mad's Avatar
redownload beta6.
Old Nov 21, 2008 | 11:59 AM
  #83
Nood1es's Avatar
can the touchscreen be incorporated in a orbital din case?
Old Nov 21, 2008 | 12:03 PM
  #84
evo4mad's Avatar
sorry this is only my hobby, so I don't have the time to create orbital din cases, but its sounds like a good idea. maybe you can get a gps navigator and start making some, I could buy them from you in bulk and sell them on the evoscan website for others who might want one.
Old Nov 22, 2008 | 09:39 AM
  #85
evo4mad's Avatar
I updated the instructions in post#1 on how to load the beta version, as i was getting too many questions regarding it.
Old Nov 22, 2008 | 03:09 PM
  #86
infini_IV's Avatar
quick question if its not to much trouble, can i view data via the graph or gauges without actually need to be logging the info ie just veiwing live stream with the evoscan 2.5? if it is possible how is it done
any help appreciated
kind regards
Old Nov 22, 2008 | 03:36 PM
  #87
randomevo's Avatar
Realtime logging is the first choice under Graphs & MapTracer - Just click what you want to see.
Pretty sure it still logs it anyways but you can watch it in real time. Very Fun/Helpful.
This feature should make the GPS DATALOGGER the coolest ish out.
Old Nov 22, 2008 | 09:33 PM
  #88
evo4mad's Avatar
Also you can load a csv log to view the historical graph, or you can use playback button on the home screen to play back the gauges
Old Nov 23, 2008 | 07:02 AM
  #89
silver9mr's Avatar
im new to tunning and logging and im wondering if the new version v2.6 will have all the features as the previous versions or will i have to download all the other versions to get them well if any of u guy could help that would be awsome
Old Nov 23, 2008 | 09:34 AM
  #90
silver9mr's Avatar
^^^^anybody???
