EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
my private website link isn't working
cavturbo@boostworld.freeserve.co.uk
i do have 2.7 beta 5
it load my log just fine, but when i load my rom i get weird pop up. Also if you look at the load. it doesn't read right.
ok I havent been following this thread much, but have been thinking about upgrading from 2.5... sorry if its been asked but I "skimmed" through most of this thread, and I have a quick question...
so my question is, I need a fresh install of version 2.6, before I can drop the new 2.7 beta5 into that folder? Meaning, I can NOT drop it into my 2.5?
Hi Hamish,
EvoScan GPS Navigator v1.7 will work on Windows CE?
I want to buy the program only and maybe there is a way to make this working.
I have a 2DIN DVD with GPS incorporated and I want to know if this can work.
Log external analog data?
I would like to log some 5V analog sensors such as oil temperature, pressure, EGT, and AFR. Currently, I do this using a "professional" logging unit (G2X from Racepak, similar to DL1 from Racetechnology). Yet, it is annoying to join&analyze two logs, i.e., the G2X one and the Evoscan log.
Is it possible to log *multiple* analog data using Evoscan/GPS?
I have seen people logging AFR using a spare ECU pin, but this doesn't scale for the number of analog channels I want to log.
The other way around is quite cumbersome, as adding all the engine sensors such as knock, injectors, bla bla becomes too expensive.
I am aware that this is not the focus of Evoscan/GPS, but at least I have a strong interest in such functionality.
The other way around is quite cumbersome, as adding all the engine sensors such as knock, injectors, bla bla becomes too expensive.I am aware that this is not the focus of Evoscan/GPS, but at least I have a strong interest in such functionality.
http://www.dlpdesign.com/usb/io8.shtml
I'm using one with Nistune, they're unbeatable for the money
Like this one?
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Maybe we could ask Hamish to make his EvoScan extensible by logging plug-ins, that way we could add almost any device for logging.
