Periphery questions:
Old Nov 22, 2008 | 11:35 PM
Deepnine's Avatar
Periphery rom location question
Hi,
if changing the periphery bits, only the first word will be changed (in red).
in ida pro you see a set of the same words:
Code:
ROM:00000FCA word_FCA:       .data.w h'8A89          ; DATA XREF: ROM:off_F364o
ROM:00000FCC                 .data.w h'8A89
ROM:00000FCE                 .data.w h'8A89
ROM:00000FD0                 .data.w h'8A89
ROM:00000FD2                 .data.w h'8A89
ROM:00000FD4                 .data.w h'8A89
ROM:00000FD6                 .data.w h'8A89
ROM:00000FD8                 .data.w h'8A89
what are the others for?
shouldn't we change them too?
thx Jan
Old Nov 23, 2008 | 12:59 AM
jcsbanks's Avatar
https://www.evolutionm.net/forums/sh...cus+map+switch
Old Nov 23, 2008 | 03:26 AM
Deepnine's Avatar
but on a stock rom, only the first set is used?
Old Nov 23, 2008 | 03:43 AM
jcsbanks's Avatar
Yes, only ever the first set on a stock ROM.
I abandoned this method of map switching since although it was easy, many of the maps you'd want to switch are not indexed in this way with the 8 item look up tables. By making new tables in spare areas of memory and making code changes it could be reinstated.
Old Nov 23, 2008 | 10:55 PM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Partially,
it seems that if ROM:F42 is enabled, MUT3B can be used to switch indexed maps,
if ROM:F42 is disabled (stock setting), index at ROM:F40 is used (0 for stock).
Old Nov 23, 2008 | 11:13 PM
Evoryder's Avatar
Sorry, I was on my way to another thread and stumbled across this one. All I saw was Chinese...
I'll close the door on my way out.
Old Nov 23, 2008 | 11:15 PM
Deepnine's Avatar
ROM:F42 is a word.
0000 is disabled, whats enabled? 0001?
Old Nov 23, 2008 | 11:24 PM
acamus's Avatar
Originally Posted by Deepnine
ROM:F42 is a word.
Yes something non zero (boolean value).
But be aware, that more than periphery bits tables are in concern.
Old Nov 23, 2008 | 11:27 PM
Deepnine's Avatar
thanks for the warning.
mrfred
Sep 14, 2022 07:08 PM
n3m3sis
For Sale - Cars For Sale
Oct 30, 2012 09:22 AM
l2r99gst
Sep 19, 2012 08:03 AM
mrfred
May 7, 2009 06:24 PM
