help reading rom
Old Nov 22, 2008 | 11:39 PM
infini_IV's Avatar
offering payment for help reading rom
i still cant get this sorted so am offering $20usd via paypal to anyone who can get it sorted for me.... please someone must know how to sort this
ive tried saving the rom from my evo 7 to ecuflash it will save it but when i try to read it it gives me the note "unknown ROM image- ecuflash could not recognize this ROM image using any of the current definitions" i have tried searching and no one seams to have a definitive solution, is there anyway i can read this, i can connect my car to a mut3 which will give me the ecu part# and rom id# would this help me get this problem solved?
thanks in advance
Old Nov 22, 2008 | 11:43 PM
Deepnine's Avatar
Is it a oem rom, or was it modified by a tuner?
If its oem rom, the you can just upload it here. With luck someone has a definition or at least can tell you the rom id.
All evo 7 ecu i have seen (not all but about 6 differend), can be patched with the 90550001.
But becarefull with the immobilizer code. Just send yourself a copy of the orginal rom by email, its my favorie backup solution.
If you delete you immobilizer code, it gets difficult.
Old Nov 23, 2008 | 12:03 AM
infini_IV's Avatar
its an oem rom
i tried it twice and named it differantly both types so not sure which one you need
Old Nov 23, 2008 | 12:05 AM
infini_IV's Avatar
second image
File Type: zip
Old Nov 23, 2008 | 12:09 AM
infini_IV's Avatar
the car is a jap import so doesnt have an immobilizer, what do you mean by patched? im very new to this
Old Nov 23, 2008 | 12:31 AM
Deepnine's Avatar
Your rom id is 98640014
Here you find a solution:
https://www.evolutionm.net/forums/sh...951&highlight=
https://www.evolutionm.net/forums/sh...light=98640014
Old Nov 23, 2008 | 12:35 AM
infini_IV's Avatar
thanks very much, would you know what i need to display it in ecuflash?
Old Nov 23, 2008 | 12:37 AM
Deepnine's Avatar
You just need the 98640014.xml
Copy it to your ecuflash directory Program files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
then open the hex file again, and it works.
Old Nov 23, 2008 | 12:43 AM
grayw's Avatar
Use this XML file, place in this directory, or where you have Ecuflash installed: C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
File Type: zip
Old Nov 23, 2008 | 12:48 AM
infini_IV's Avatar
i must be missing something i thought you could then open it in ecuflash and you can edit things, just trying to play around and learn how it all works?
Old Nov 23, 2008 | 12:53 AM
Deepnine's Avatar
Check if File > Options > User level is set as "developer"
Old Nov 23, 2008 | 01:00 AM
infini_IV's Avatar
have changed it to developer but it still isnt visible when i click open rom it comes up "look in ecuflash" but there is nothing in there? i do appreciate your help so far sorry if im frustrating you im a beginner
Old Nov 23, 2008 | 01:06 AM
grayw's Avatar
The rom file you have attached to this thread is incomplete, sould be around 256k to start with.
Old Nov 23, 2008 | 01:10 AM
infini_IV's Avatar
the file i attached in the zip folder says its 264kb
Old Nov 23, 2008 | 01:18 AM
grayw's Avatar
None of the attached files are that size unzipped. Can you email it?
