ecu unlocker
Old Nov 29, 2008 | 01:40 PM
lan_evo_mr9's Avatar
ecu unlocker
I downloaded the unlocker in the zip. When I open the application a little active matrix box pops up and thats it. Pretty sure something else is supposed to happen. Running vista- does that matter?
Old Nov 29, 2008 | 01:44 PM
~BoOsTeR~'s Avatar
I believe you're supposed to have it open in the background while using EcuFlash if you're having issues with a locked Ecu and using said flashing tool.
Old Nov 29, 2008 | 01:50 PM
jcsbanks's Avatar
Or just exit the unlocker with alt-f4 rather than the usual method and it will leave the changes in the registry and you won't need to run the unlocker each time.
Old Nov 29, 2008 | 01:54 PM
So I have the ecuflash running and connected to said vehicle and then open the unlocker tool?
Old Nov 29, 2008 | 02:08 PM
jcsbanks's Avatar
No, run unlocker first and leave it open when you run Ecuflash. If you want to never have to use the unlocker again, use alt-f4 to close the unlocker.
Old Nov 29, 2008 | 02:13 PM
I see, thank you for the clarification. By the way jcs- the phantom knock patch is absolutely fantastic and is performing like a wet dream. Thanks again for all the hard work and time you put into it.
Old Dec 6, 2008 | 09:59 PM
shangai's Avatar
It Worked For Me!
Old Jun 26, 2009 | 05:43 AM
poombah's Avatar
I get same issue:
[20:42:29.683] J2534 API Version: 04.04
[20:42:29.683] J2534 DLL Version: 0.50.2464 Jan 29 2009 10:58:58
[20:42:29.683] Device Firmware Version: 1.06.2536
[20:42:31.826] sending init sequence 1 (0001)
[20:42:35.100] sending init sequence 1 (0003)
[20:42:38.395] sending init sequence 1 (FFFF)
[20:42:41.680] sending init sequence 1 (F0F0)
[20:42:44.394] no response to any known code
[20:42:44.404] interface close
Old Oct 15, 2009 | 11:37 AM
eliethemonster's Avatar
hello . i need to connect als in the evolution 8 i have the rom but i dont now witch wir i need to connect to the switch
Old Oct 15, 2009 | 11:45 AM
devilsfutbol17
Jun 20, 2017 08:28 PM
unicycle
Aug 20, 2016 08:25 AM
jimbo74
Lancer Troubleshooting
Jan 3, 2015 06:49 AM
supwiddiss
Jul 8, 2007 07:09 PM
