Calibration Id
Old Apr 17, 2010 | 01:51 AM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
first byte:
0x10 = MB
0x20 = MD
0x30 = MR
0x60 = MN
0x80 = 1860
Old May 16, 2010 | 06:58 PM
Ceddy's Avatar
Here is how I setup the "ECU ID Case Part Number" table.
Credit goes to Acamus for finding info.
(This is for a H8, addresses need changed for Evo ecu.)
By using a 3D table, you can have a different scaling in the Axis.
First add Scaling:
Code:
<scaling name="CaseAlphaNumeric" storagetype="bloblist" storagebits="8">
	<data name="MB" value="10"/>
	<data name="MD" value="20"/>
	<data name="MR" value="30"/>
	<data name="MN" value="60"/>
	<data name="1860" value="80"/>
</scaling>
And Table:
Code:
<table name="ECU ID Case Part Number" category="Identification" address="10233" type="3D" level="4" scaling="Hex8">
	<table name="Part Number" type="Static X Axis" elements="3">
		<data>PN2 .</data>
		<data>PN3 .</data>
		<data>PN4 .</data>
	</table>
	<table name="PN1" address="10232" type="Y Axis" elements="1" scaling="CaseAlphaNumeric"/>
</table>
Old May 23, 2010 | 10:34 PM
acamus's Avatar
Same for SH ecus.
But I think it will not work for 1860, as PN2 is already 60
Code:
<table name="ECU ID Case Part Number" category="Identification" address="f6B" type="3D" level="4" scaling="Hex8">
		<data>PN2 .</data>
		<data>PN3 .</data>
		<data>PN4 .</data>
	</table>
		<table name="PN1" address="f6a" type="Y Axis" elements="1" scaling="CaseAlphaNumeric"/>
	</table>
Old Jun 2, 2010 | 05:26 PM
hackish's Avatar
acamus, I thought i'd emailed that whole routine to you.
I've actually decyphered all the OBD2 requests...
The one in question is called: process_obd2_mode9
The only thing I found really useful was in the process_obd2_mode27 which, once you seed/key allows you to change the VIN number.
-Michael
Old Jun 2, 2010 | 11:01 PM
acamus's Avatar
I cannot really remember the mail. Nevertheless, there is no mode 27 in older platform based on H8/SH2.
Have you come accross the flash counter in m32r code? I have been told it is possible to check how many flash attempts were done with MUTIII. I suspect this would be in ETACS, but I have never really seen it m32r code.
Old Jun 7, 2010 | 03:10 AM
hackish's Avatar
The m32r seems to store the flash counter in the serial eeprom but I believe it's disabled in the code.
-Michael
counterforce661
Oct 14, 2014 09:49 PM
JohnnyTSi
Northwest Region
19
Dec 6, 2011 04:16 PM
worksevo89
Nov 17, 2008 01:33 PM
silex
Jul 28, 2006 07:01 PM
