wgdc correction based on MAF IAT
Old Dec 13, 2008 | 08:12 AM
Slo_crx1's Avatar
This would be a highly useful tool, the other day in mid-20's temps I spiked almost 28psi in 1st and 2nd gear, but once it warmed up into the mid 50's a few days later I had the normal 23psi again.
Old Oct 29, 2010 | 03:04 AM
VGergo's Avatar
Hello,
If i copy this :
<table name="MAF IAT WGDC Correction" category="Global Boost Control Settings" address="512dc" type="2D" scaling="OffsetWGDC">
<table name="Degrees" address="512c6" type="Y Axis" elements="7" scaling="Temp"/>
</table>
in the 88580714 V7 will this awsome correction work ?
How will the ecu now to make correction only if the base wgdc not 100 ?
Nowdays did someone play with this table on 3 port solenoid ?
Old Oct 29, 2010 | 04:12 AM
tephra's Avatar
You need to run V7 to be able to use that table
Old Oct 31, 2010 | 04:12 AM
VGergo's Avatar
and in every V7 ? 88580714 jdm evo 9 V7 too ? I can see right values when I copy that things in the xml, but will this work ?
Old Oct 31, 2010 | 10:32 PM
tephra's Avatar
i cant remember if different V7 roms have different locations for that table..
Just use the XML included in the V7 zip for the ROMID you are working on...
tephra
Apr 22, 2026 11:03 AM
richardjh
Nov 6, 2024 04:41 AM
S15me2
Dec 8, 2016 08:22 PM
TrendSetter
Mar 14, 2016 08:26 AM
hkumar
11
Sep 9, 2013 07:55 PM
