Testing 3 Port
Old Dec 20, 2008 | 08:45 PM
RoadSpike's Avatar
Testing 3 Port
Is there a simple way to test these things?
I just installed one on my car and it doesn't appear to be doing anything. Its a gruppe-s 3 port copy, i got it for convenience since it was very close to the proper ohms (about 28.5ohms on mine).
The boost is always at wastegate pressure from 50% WGDC to 90% WGDC.
Installed like so:
The metal boost side goes to the turbo nipple.
The open by default side goes to the wastegate
The closed side to vent to intake
Old Dec 21, 2008 | 01:55 PM
RoadSpike's Avatar
Well figured it out today maybe this will help future 3 port modders.
First off the reason it didn't work as expected was I mistakenly reversed the compressor and wastegate lines when i hooked it up.
I got to this conclusion by testing the electrical lines thinking they were faulty. While the car is on/or running the voltage on the solenoid runs a steady 12volts but not enough current to activate the solenoid, probably some ecu testing thing. I tested my adapter for voltage and it was good.
Secondly I got a standard 9 volt battery and using some speaker wire, was convenient, I jumped the solenoid and found it was switching properly. To further test this i plugged it back into the car with no hoses and had a buddy blip the throttle to 100% for a moment. This blipping action triggers the solenoid and i found it was switching properly by trying to blow air into the wastegate port. Upon switching it went to the bleed port.
So i concluded that i had mistakenly hooked up the wategate port to the compressor port by mistake on the night I installed it.
Old Dec 21, 2008 | 02:15 PM
Nurburgring's Avatar
Just to clear this up once and for all, could you please label the numbers in this picture, what they´re supposed to be connected with?
Old Dec 21, 2008 | 03:02 PM
RoadSpike's Avatar
Sure I'll draw it out too.
1) Intake
2) Wastegate
3) Compressor
