Tephra Rom Mod - Ver 6 ??????
I noted a lot of tip-in knock initially with the 94170015 v5.10 ROM.
I started over fresh with a known good ROM and xml and I really haven't had much of an issue since. I get the occasional knock light that I believe is a false knock event, but it's pretty rare now.
I don't know what went wrong on the first time I installed 94170015 from 94170008, but it was pretty much every time I got on it I was having an issue with false knock and I could not tune it out. I've just caulked it up to something I did wrong and moved on and the car runs great on v5.10 and I haven’t even touched the newly defined knock tables.
If you are having issues, I'd suggest starting fresh with a known good ROM and XML.
newb question
do I need another pin for the cable/ecu to get the alt. maps working w/ ICS, or can I just enable alt maps master ACD0F=1, AutoICS=2. Im a lil behind, trying to get a grap on this...
TIA
TIA
Pd1
Dec 6, 2021 01:28 AM
Darkdragon4862
69
Aug 22, 2012 10:03 AM
I am thinking of the ACD button activation method.
