Any success with bleeding AYC with Evoscan and Limitless cable?
Old Jan 9, 2009 | 11:48 AM
BarryC's Avatar
Originally Posted by jcsbanks
If it is just the case of the right cable and we know if works on JDM/UK 8/9 then I'll just order it rather than reinventing the wheel, but do we know if it does?
I have to bleed the AYC on a 7 gsr tomorrow will test it properly then
Old Jan 9, 2009 | 12:13 PM
travman's Avatar
This thread makes me look forward to when I can finally have my acd tc swapped for a non-acd tc and get rid of this garbage......seems more of a pain than acd is even worth.
Old Jan 10, 2009 | 09:26 AM
fil78's Avatar
+1
I have the same issue as jcsbanks on my IX . I have reworked my openport 1.3M cable as decribed by Hamish and in Barryc post above but it doesn't work : no actuator activation & when logging the AYC ecu , Evoscan connect to the ecu but the data's are wrong (always $FF) .
would really appreciate confirmation that the limitless cable works OK before ordering one
Old Jan 10, 2009 | 03:45 PM
JoeBee's Avatar
I have build my own bleeder circuit.
I remove the Pump Relay in the engine bay and place a relay in the contacts which I can switch on with a switch. I have 3 additional switches (One two-way switch) that supply the 4 solonoids with 12V an let the fluid flow.
Additionally I measure the voltage of the pump so that not to much pressure will build (1.4 Volt is the shut off Voltage)
I disconnect the 8 Pin connector at the pump and plug the lines from my circuit to the pins in the connector that goes to the pump. For this pin connectors I use the female contacts from a standard PC 12V, 5V connector.
This works fine for me and I have change my pump 6 times now ( 2 new pumps was leaky)
Old Jul 27, 2010 | 11:39 AM
And's Avatar
And
Originally Posted by fil78
+1
hi did you find a solution to logging the FF's for everything as I have the same issue? thanks
Andy
Old Aug 1, 2010 | 06:55 AM
fil78's Avatar
Andy
unfortunately no . it was still not working when I tested it in May (was with the 2.7 beta version )
alain
Old Aug 1, 2010 | 07:16 AM
Appauldd's Avatar
Just use 2 people and bleed it the manual way.
One person under the car working the bleeder, on in the car working the ignition key and the gas pedal.
Turn on the car but not start it. Open the bleeder. Floor the gas. You will hear the pump kick on for about 3 seconds. Close the bleeder. Shut off the car.
Rinse and repeat about 6-8 times.
Bleeding the ACD is EASY.
Yeah, I know it said AYC...but do you really bleed the yaw control ? ? ? HUH ?
Old Aug 1, 2010 | 08:33 AM
And's Avatar
And
i tried this also and it didn't work, couldn't get the pump to activate, although I know its ok as my local dealer was able to active the pump etc
Old Aug 1, 2010 | 08:55 AM
Butcher_DSM's Avatar
another way exist, i try on my EDM IX and it work
1. open Evoscan
2. select ECU - AYC
3. check all boxes in the "item to datalog", exept "ABS monitor"
4. click on the "Start Datalogger"
AYC pump will start and working, until click on "Stop Datalogger"
Old Aug 2, 2010 | 09:16 AM
fil78's Avatar
1. open Evoscan
2. select ECU - AYC
thks - looks nice because then 1 person alone can do it !
will try . do you need to have the engine running before step 4. ?
Old Aug 2, 2010 | 02:29 PM
no, only ignition
Old Aug 3, 2010 | 11:47 AM
And's Avatar
And
1. open Evoscan
2. select ECU - AYC
tried this but it didn't work for me
Old Aug 4, 2010 | 02:13 AM
strange
all look like this ?
Old Aug 4, 2010 | 06:48 AM
And's Avatar
And
yeah except i'm using the OP2 cable and the OP1.3 cable with no success
hearnoevo
Jul 12, 2025 01:25 PM
Red_KY_Evo
For Sale - Miscellaneous Automotive
May 1, 2017 07:22 AM
poonta
Oct 24, 2016 06:03 PM
JrCRXHF
Jan 31, 2012 11:10 AM
FTS EVO
Jan 10, 2010 08:37 AM
