ecu flash jacked up!!
Old Jan 12, 2009 | 07:46 PM
tephra's Avatar
well its not loading the XML properly because of the line 329 thing.
if you reinstall make sure you clean out the xml directory.
then before making any changes see if it loads your ROM ok.
Old Jan 12, 2009 | 07:52 PM
Dyrexion's Avatar
yeah i did that twice now. it doesnt make sense.
I uninstalled it.
Deleted everything.
Rebooted.
Made sure it was all gone.
Installed.
Tried to load the stock rom for 90015 i get the 329 thing and all the infos missing or greyed. I mean its one thing if i screw up an xml file but it doesnt make sense that the files included with 1.4 dont work either. Are there any other files that ecu flash uses of the computer that could cause this?? Maybe ill do a system restore...
Old Jan 12, 2009 | 07:55 PM
tephra's Avatar
1.40 yeah?
hrmm very strange.
when you install ecuflash just reset the "rommetadata directory - in options menu" to the correct place.
maybe you have a copy elsewhere that is being loaded...
Old Jan 12, 2009 | 08:50 PM
Dyrexion's Avatar
Originally Posted by tephra
ok - just copy/paste the last 50 lines from that file in here...
ps - this is what ecuflash *should* look like when you load+open a rom
Code:
[14:50:40.671] Version 1.40.2178
[14:50:40.687] 19 memory models read.
[14:50:40.703] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[14:50:45.500] 325 ROM metadata models scanned.
[14:50:45.500] checksum module "subarudbw" loaded.
[14:50:45.500] flashing tool "wrx02" loaded.
[14:50:45.500] flashing tool "wrx04" loaded.
[14:50:45.500] flashing tool "sti04" loaded.
[14:50:45.500] flashing tool "sti05" loaded.
[14:50:45.500] flashing tool "mitsukernel" loaded.
[14:50:45.500] flashing tool "mitsukernelocp" loaded.
[14:50:45.500] flashing tool "shbootmode" loaded.
[14:50:45.578] flashing tool "shaudmode" loaded.
[14:50:45.578] flashing tool "subarucan" loaded.
[14:50:47.984] 88580013 (93 tables) inheriting evo9base_20081101 (136 tables)
[14:50:48.000] 88580614 (56 tables) inheriting 88580013 (129 tables)
[14:50:48.062] 524288 byte image read.
[20:48:44.497] Version 1.40.2178
[20:48:44.513] 19 memory models read.
[20:48:44.514] scanning for metadata models in C:/Program Files/OpenECUB/EcuFlash/rommetadata
[20:48:48.190] 319 ROM metadata models scanned.
[20:48:48.190] checksum module "subarudbw" loaded.
[20:48:48.191] flashing tool "wrx02" loaded.
[20:48:48.192] flashing tool "wrx04" loaded.
[20:48:48.192] flashing tool "sti04" loaded.
[20:48:48.193] flashing tool "sti05" loaded.
[20:48:48.193] flashing tool "mitsukernel" loaded.
[20:48:48.193] flashing tool "mitsukernelocp" loaded.
[20:48:48.193] flashing tool "shbootmode" loaded.
[20:48:48.232] flashing tool "shaudmode" loaded.
[20:48:48.233] flashing tool "subarucan" loaded.
so i reinstalled why do you have these two lines loading:
Old Jan 12, 2009 | 08:57 PM
tephra's Avatar
im opening a 88580014 rom, so it inherits 88580013 which in inherrits evo9base...
was just an illustration.
reset your rommetadata directory (whats C:/Program Files/OpenECUB???)
Old Jan 12, 2009 | 11:15 PM
codgi's Avatar
If this is still happening after an install/re-install your old (corrupted) xml file(s) are still there on the machine. Which file did you change? Was it the evo base xml file or the one specific for your rom?
Depending on that we can do a few more tests to help you prove this .
Old Jan 13, 2009 | 05:43 AM
Dyrexion's Avatar
It stopped actually. I uninstalled for the 3rd time, did a system restore to the laptop back to the 8th, and the roms all load now. I think some other critical system files or somethin like that were corrupted at some point that were repaired by the restore. I mean 2 installs youd think would fix it.
Old Jan 13, 2009 | 07:17 AM
JoeBee's Avatar
Long time ago I have a similar problem.
Something in the "rommetadata" directory was bad.
I have rename the whole rommetadata directory to rommetadata.old
Then I install ecuflash again and try to start it. The error went away and I copy only my modified xml files back one after another to find the bad one but everything works.
Then I make a compare between the directory's and found a bad file template "read_wrx02.xml" which I never use (Subaru) but which was bad.
Whatever, every thing works again.
Old Jan 13, 2009 | 10:38 PM
codgi's Avatar
Probably was still the old xml files remaining on the system. What JoeBee describes above is probably what happened to you. Anyway glad it worked out .
Really uninstall should blow out that directory but i guess in some situations it does'nt...
Old Jan 13, 2009 | 10:50 PM
Dyrexion's Avatar
back in the 1.29- days i used to have that problem alot. Ecuflash is terrible at cleaning out its files when being uninstalled. I also told it to put it in /ecuflashA instead of the standard location.
mrfred
Dec 15, 2022 11:13 AM
mrfred
Feb 26, 2022 06:16 PM
city
Jun 2, 2017 08:34 PM
Donnyevo7
Jan 3, 2016 08:01 PM
chmodlf
Aug 24, 2008 01:17 PM
