Load dropping off
Old Jan 14, 2009 | 03:07 AM
tephra's Avatar
^ just less.
my stock ix clocks in at ~1900 hz at 7500 @ 20psi
Old Jan 14, 2009 | 08:59 PM
03whitegsr's Avatar
Something odd happened in that log at sample 47.
Time takes a 2 second jump...
I'd get another log and see if it does it again.
Old Jan 20, 2009 | 09:09 PM
Dapper Dan's Avatar
Ok, this is really starting to irritate me. I put the stock maf back on, and the results were the same. everything Ive checked, wastegate, boost controller, maf and translator, compression, and boost leak test. Does anyone have any suggestions at all?
my maf hz are very low for a 35r so something is going on but I just dont know what.
Does anyone have a stock 94170015 they can email me. Im seriously trying everything I can think of right now.
Old Jan 20, 2009 | 09:11 PM
GST Motorsports's Avatar
couple teeth off on the tbelt?
Old Jan 20, 2009 | 09:19 PM
Dapper Dan's Avatar
You know I was actually just thinking about that tonight, Will check that tomorrow.
Old Jan 21, 2009 | 06:08 AM
deathtracks's Avatar
I know you mentioned it is producing 26-27 lbs through the rev range but it sounds like it is the wastegate hanging open or blowing open prematurely. I wouldn't be looking at tuning since the only thing that changed was the motor build. I would look at the turbo itself or a leak pre-turbine that wouldn't show on a boost leak test.
Old Jan 21, 2009 | 09:53 AM
Dapper_Dan's Avatar
I have checked all of that overreally well. I even took the wastegate apart and checked the diaphram.
Old Jan 21, 2009 | 07:33 PM
Dapper Dan's Avatar
Well The timing was off, by a few teeth. I have no idea how it jumped but i fixed it. I went to take it for a test drive and got pulled over before I even got to test it out, It drives smoother tho so im sure it took care of the problem. Thanks for helping out everyone!
-nick
Old Jan 22, 2009 | 12:34 PM
Dapper Dan's Avatar
Well i just did a pull on 25 psi and and my airflow is 2450 HZ seems a little better and it pulls harder. But im only hitting 280 load and it still drops of slightly but not nearly as bad.
Old Jan 24, 2009 | 05:14 AM
Mellon Racing's Avatar
compare your old logs to new at the same boost level and make sure you really have a problem at this point.
Old Jan 24, 2009 | 01:12 PM
RoadSpike's Avatar
Whats your air temp on the logs is it climbing?
Old Jan 30, 2009 | 11:15 PM
Dapper Dan's Avatar
My air temps stay about the same through all of my pulls. Im hitting 330 load and its dropping off to around 280 at 9000 rpms
Old Jan 31, 2009 | 12:34 AM
RoadSpike's Avatar
Ah that's a shame i was hoping rising intake temps would explain the drop off in load.
Old Jan 31, 2009 | 07:20 AM
Ted B's Avatar
This was said before, but load mirrors the torque curve, not the hp curve, and therefore it will decrease after the torque peak. Airflow in Hz mirrors the hp curve.
Old Feb 25, 2009 | 10:10 PM
Dapper Dan's Avatar
just wanted to update this, my turbo was jacked up. Looks like something went through the exhaust wheel
