who are the best shops a tuning with ECUFLASH (country wide)
Old Feb 2, 2009 | 08:42 AM
  #31
steadly2004's Avatar
Originally Posted by Slo_crx1
That's good to know, I misread and thought he said 2g, and the usual case seems to be codes for crank and cam sensor for some odd reason with them, although switching over to an EDM rom usually takes care of that issue. Rather odd if you ask me. Also an FYI, disabling the periphery bits that controls EGR and other emissions checks does not mean it'll pass any emissions inspection. It only means the ecu skips those checks, and it'll come up in emissions scans as a system problem for those who actually get a diagnostic machine hooked up while having the smog check. States that don't do the diagnostic smog checks you should have no problem with, although technically it's still illegal lol. Of course, so is a cat-back in many states.
It actually passes the OBDII (with the computer hooked up) check here in NC. Only if you disable something like the "rear O2" and it causes another check like the catalyst coverter check to never complete will it not pass. You can check if you'll pass or not with scantech, it displays which tests are active, NA, pass/fail ect.
It actually shows up as NA on the computer that checks it. Just like checking for trailer brakes on most cars that don't have them, or O2 sensors 3 and 4, which aren't there on 4cyl engines in general.
Howulikemyevo
46
Feb 9, 2018 10:45 PM
wesleylawson6
Lancer Engine Tech
Jan 7, 2015 05:27 PM
buford
14
Apr 23, 2013 04:58 AM
turbo speedy
Mar 2, 2010 02:11 PM
PHILLY EVO
Mar 7, 2009 08:43 AM
