need Evo 9 owner to test rear O2 *heater* sim patch
Old Jan 26, 2009 | 09:40 AM
Darwinn's Avatar
88840016 \ 17
I have NO read o2 on car and ready to test right now.
Old Jan 26, 2009 | 09:44 AM
MR Turco's Avatar
If I have an O2 plug i can probably take mine out tonight. I will report back when i get home.
Old Jan 26, 2009 | 09:56 AM
mrfred's Avatar
Originally Posted by Darwinn
88840016 \ 17
Sorry, I need someone with an 88590015 ROM. I'm sure patches for other ROMs will quickly follow.
Old Jan 26, 2009 | 10:01 AM
travman's Avatar
I have a friend that removed his rear O2 - he is 88590015. For now he is driving around with a cel, i could probably test this for you on his car. I originally told him to do the resistor mod, but now that I see this he will be happy of the option.
- Trav
Old Jan 26, 2009 | 01:20 PM
EvoBroMA's Avatar
PM sent...
I am currently running without a Rear o2 sensor, with the code thrown.
running a tweaked 88590015. (jdm map, diff boost settings, etc.)
Old Jan 26, 2009 | 07:26 PM
GiGas's Avatar
Hi folks.
I am newbi into EVO and I am not shure that I understand the problem.
During my work with the old ATR I found a nice and cheap solution to aviord MIL (CEL) when you remove a catalysator or place a highflow catalysator.
Now I had used the same solution on my IX. Extending the mounting soket to 4cm will keep the O2 sensor out of the gas stream and no MIL (CEL) will occur.
Guess that you guys know this and you need the programming solution.
Old Jan 26, 2009 | 07:42 PM
logic's Avatar
We're discussing a solution that permits you to completely remove the rear O2 sensor from the car; ie. completely unplugged from the wiring harness. The mechanical solution you mentioned is workable for those who can retain the sensor, but isn't ideal for all of us.
Old Jan 26, 2009 | 07:55 PM
GiGas's Avatar
logic.
Yes i see that a bit change at the right spot in the code would be fine option to have.
Thanks
Old Jan 26, 2009 | 08:28 PM
mchuang's Avatar
woohoo i can ditch the o2 simulator
Old Jan 26, 2009 | 08:56 PM
GotWheelHop's Avatar
Let me know when you are ready for 94170015, good sir. I can unplug it in a matter of seconds.
Old Jan 27, 2009 | 03:18 PM
daisaw1219's Avatar
bump has anyone applied the patch??? Is it a go or no.
Old Jan 27, 2009 | 03:56 PM
mrfred's Avatar
I still need to write the patch. Hoping to do it before the end of the week.
Old Jan 27, 2009 | 08:24 PM
PlanoEvo's Avatar
I'm ready
Old Jan 29, 2009 | 07:07 PM
bboypuertoroc's Avatar
Veteran: Army
Old Jan 31, 2009 | 06:49 AM
THUB's Avatar
I was planning on just doing the resistor mod when I had some time so if you need a tester for 94170015, I'll do it.
