SD - first test success
Old Feb 6, 2009 | 01:50 AM
  #61
tephra's Avatar
Good work john - this might actually be the first "universal" SD solution, universal because it should be pretty easily portable to other ROMID's.
I am tempted to cancel my order of the perrin intake and just run an amsoil filter stuck onto the turbo with SD of course. MRBOV should vent fine to atmo!
Old Feb 6, 2009 | 03:15 AM
  #62
justboosted02's Avatar
its gonna be screen material for me
Old Feb 6, 2009 | 08:24 AM
  #63
gsrboi80's Avatar
Filter on turbo FTW
Can't wait to get this all 100%
Old Feb 6, 2009 | 10:59 AM
  #64
jcsbanks's Avatar
I did full throttle work with it today, plus driving in traffic. Not had to change the original settings I posted. It drives just like it did on the MAF except there is no lift off jerk
I have killed the OBD II baro code as well. Just one code remaining which keeps the CEL on. It is P0110 - volume airflow sensor. Think I have to kill some more codes.
Old Feb 6, 2009 | 11:08 AM
  #65
cossie1's Avatar
Sounds promising
Old Feb 6, 2009 | 11:35 AM
  #66
MR Turco's Avatar
Awesome news, i just hope we can pass emissions.
Old Feb 6, 2009 | 11:54 AM
  #67
wreckleford's Avatar
Have you directly compared logs pre/post MAF to MAP? This almost sounds too good to be true I have an AEM 3.5 bar and a GM temp sensor so I am ready to test this out.
Old Feb 6, 2009 | 12:12 PM
  #68
jcsbanks's Avatar
All looks the same. I couldn't tell which is which except for the smoother lift off running SD.
I had to unplug the MAF sensor to believe it myself!
Old Feb 6, 2009 | 12:18 PM
  #69
l2r99gst's Avatar
Where do we sign up? I'm first in line.
Old Feb 6, 2009 | 12:19 PM
  #70
jcsbanks's Avatar
Let me remove this last CEL and then I'll put up a programmer's guide to the routines to tweak.
Old Feb 6, 2009 | 01:07 PM
  #71
RoadSpike's Avatar
Sweet you think i'm going to have to move over to a different rom id?
I'm in the dreaded 96240008 id group which isn't heavily supported
I'd also like to know if running non standard map sensors is going to be an issue. I tapped a 5bar zeitronix sensor into the mdp location and have it setup on my rom correctly without disabling the EGR routine no cels yet.
Old Feb 6, 2009 | 01:10 PM
  #72
MR Turco's Avatar
Sounds great! I am also ready for testing if needed.
Old Feb 6, 2009 | 01:13 PM
  #73
cossie1's Avatar
Does this mean I might beable to fit this huge K&N filter I have, this weekend ???
Old Feb 6, 2009 | 02:22 PM
  #74
todd6027's Avatar
you might have to log out to do that
Old Feb 6, 2009 | 02:25 PM
  #75
cossie1's Avatar
Not heard of wi-fi ??
