Acceleration Enrichment Map Discovery
Old Feb 23, 2009 | 01:49 PM
  #31
mrfred's Avatar
Send me the address for the proposed async subroutine for 88590015, and I'll take a look at it tonight or tomorrow evening.
Old Mar 31, 2009 | 10:45 AM
  #32
mplspilot's Avatar
Any updates on this?
Can someone pls post the address for "Asynch Accel TPS v RPM" for 94170015?
Lean tip-in on cold car has been driving me nuts lately as im not a big fan of sitting there, warming my car up since my work commute takes less time than a warm-up.. a whopping 2 minutes..
Old Apr 9, 2009 | 10:48 AM
  #33
mplspilot's Avatar
Bump for asynch enrichment vs Temp or RPM addresses for 94170015.... anyone?
Old Apr 12, 2009 | 02:33 PM
  #34
THUB's Avatar
It looks like it's the same as the def. for 0014 to me. They usually are.
Old Apr 12, 2009 | 07:41 PM
  #35
mplspilot's Avatar
Where are the 0014 Asynch def's? Can you post those?
Old Apr 12, 2009 | 08:42 PM
  #36
shadow1's Avatar
No love for the 96940011 rom?
Old Apr 12, 2009 | 09:14 PM
  #37
fixem2's Avatar
^^Switch to the 96530006 ROM and get all the love you want!!
Old Apr 12, 2009 | 09:41 PM
  #38
THUB's Avatar
Sorry misunderstood what you were asking for. I got nothing.
Does the 96530006 rom work for 9417xxxx Evos? I'd never heard for sure.
Old Apr 13, 2009 | 07:29 PM
  #39
Appauldd's Avatar
94170015
<table name="Accel Enrichment" address="3864" level="2">
<table name="RPM" address="6406" elements="15"/>
</table>
Old Apr 13, 2009 | 10:10 PM
  #40
mplspilot's Avatar
Originally Posted by Appauldd
94170015
</table>
This is an accel enrichment map that comes default with ECUFlash.. Which by the way isn't really accel enrichment AFAIK... Im looking fo Async Enrichment map.... the one merlin.oz talks about on the 2nd page of this thread: https://www.evolutionm.net/forums/6720789-post22.html
Old May 5, 2009 | 11:15 PM
  #41
R/TErnie's Avatar
bump for results.
Old May 6, 2009 | 08:35 AM
  #42
mplspilot's Avatar
Since the thread got bumped and if anyone cares, I fixed my lean tip-in that was resulting in the not so pleasant RPM drop by disconnecting the top clutch switch.
Old May 6, 2009 | 09:21 AM
  #43
fixem2's Avatar
How would the top clutch switch cause this behavior?
Old May 6, 2009 | 10:42 AM
  #44
mplspilot's Avatar
I don't know. Every time I push the clutch on the cold car, the IPW gets cut leading to lean condition and therefore the RPM drop and i get a stumble.. Once i disconnected the switch the issue disappeared.
Old May 6, 2009 | 11:03 AM
  #45
fostytou's Avatar
EvoM Community Team
Interesting as I've never had that switch connected. I thought that switch was specifcally just for a ground to the starter relay. Am I getting my top/bottom switches mixed up?
