How do you log boost on EvoScan
Old Feb 20, 2009 | 04:57 AM
  #31
SkyNight's Avatar
Secondary air supply on the EVO it's used to maintain the spin of turbo.
SAS is used to have a better response in OFF/ON operation. SAS introduced "fresh air" in the exhaust manifold when throttle is off.
Old Mar 5, 2009 | 12:08 AM
  #32
ghamatos's Avatar
Originally Posted by germanracing
Also, can I use the AVC-R's sensor to do it somehow?
According johnf's, grayw's and cossie1's instructions, to use the AVCR pressure sensor to log boost with evoscan, u have to take a feed from the AVCR harness blue wire and put it into i.e. pin 73 in the ECU. Then u put in Evoscan (@Eval) this formula 0.019224*x-1.47065 to get a pressure reading in BAR. Log MUT 38 (=JDMmap, request 38, which is already set up in Evoscan, u just change the formula).
+ ecu pins from here
http://www.dsm-ezine.com/evo9pins.html
Evo ECU pin outs - I to X !!
http://www.lancerregister.com/showthread.php?t=196839
Read:
https://www.evolutionm.net/forums/ec...ing-boost.html
I will try it soon also. Pls correct me if I miss something.
Gruesse
Old Mar 9, 2009 | 11:50 AM
  #33
fil78's Avatar
Read:
Gruesse
Hi
did you test it on a IX because the MAP pin # related to MUT request 38 is pin 92 - no ?
I guess you have (like me) a IX EDM wich do not have MAP wiring , so its very interesting to know if the MAP poll routine is implemented in xxx16/17 fw. !
Alain
Old Mar 19, 2009 | 07:57 AM
  #34
ghamatos's Avatar
Originally Posted by fil78
Hi
Alain
Yes I also have a IX EDM w/o MAP and I need to log boost for a better remap after the latest mods.
I connected (wire + 2 clamps to avoid cutting) the blue wire from the avcr to the wire coming out of ecu pin #73.
Then at evoscan JDM MAP:
RequestID:38
Eval:0.019224*x-1.47065
Unit: BAR
MetricEval:
MetricUnit: Bar
ResponseBytes:1
GaugeMin:0
GaugeMax:3
ChartMin:0
ChartMax:3
ScallingFactor:1
and ... not logging boost.
Any advise please what to try next? Connection, other pin (#92?) or evoscan setup?
evodziobak
Oct 25, 2011 05:17 AM
evokid511
Oct 29, 2009 07:08 PM
94170008
Aug 14, 2008 07:47 AM
leecavturbo
Jul 1, 2008 12:14 PM
coolguycooz
Sep 27, 2006 04:56 PM
