TephraMOD V6 - testing!
Old Jun 26, 2009 | 02:04 PM
  #1006
evo8dad's Avatar
Originally Posted by l2r99gst
FYI, that link is for V7T5, not the latest V7T6 with the fixes/changes mentioned by tephra.
Yeah I knew that but, I was able to get v7t6 working on a 96940011 car using that phenem's v7t5 ROM as a base but, with v7t6 .xml data.
Old Jun 26, 2009 | 02:07 PM
  #1007
l2r99gst's Avatar
Just using the v7t6 xml isn't using the v7t6 ROM.
So, according to TTP, the v7t6 ROM isn't working. I think this is what Tephra wanted to know.
Old Jun 26, 2009 | 02:47 PM
  #1008
evo8dad's Avatar
Gotcha. Yeah I just tried v7t6 on a 94170015 car and it didn't work either.
Old Jun 26, 2009 | 03:03 PM
  #1009
scheides's Avatar
EvoM Moderator
Originally Posted by tephra
I am going to skip V6 and go straight to V7.
I am just waiting for ppl to test 96530006 V7T6 (a few pages back) and then I can release other ROMID's
Tephra,
Alt-maps working via ACD0F input CONFIRMED WORKING! Got my car back together (headgasket ) this week with a ported head, this was a great surprise to see another test for your final release! Spent a bit today copying tables over and I'm very glad to say that my alt-map setup has come back to life!
THANK YOU TEPHRA!
Old Jun 26, 2009 | 03:11 PM
  #1010
GST Motorsports's Avatar
Originally Posted by TTP Engineering
Well then the V7T6 is not working with the 96940011 cars it seems.
Works here. Looks like it works for scheides above as well.
Old Jun 26, 2009 | 03:20 PM
  #1011
scheides's Avatar
EvoM Moderator
Sorry I missed this. Just do the immob disable and you should be good to go, not sure what the prob might be. Both T5 and T6 worked fine for me!
Old Jun 26, 2009 | 03:52 PM
  #1012
Asmodeus6's Avatar
So phenem's immob code change works on T5, not T6. For T6 you killed the immob scheides?
I'm in on this. Just let me catch up. (96940011 car)
Old Jun 26, 2009 | 05:23 PM
  #1013
phenem's Avatar
Hey guys,
I am working on another edit, and will have it updated to v6 by tomorrow sometime. I have been busy with work and have not had any time to update to v6. I will post up the same edit as last time so everyone can just "plug n chug" like before.
~Zach
Old Jun 26, 2009 | 05:39 PM
  #1014
evo8dad's Avatar
Originally Posted by phenem
Hey guys,
~Zach
What changes do you make - is it to the .xml data or something else? I dug through the .xml stuff but, couldn't find what you were doing different, although I never grasped the whole coding thing - just the tuning thing
Old Jun 26, 2009 | 06:15 PM
  #1015
tephra's Avatar
evo8dad
I got a real nice/cheat idea for you.
Leave your normal boost tables (ie the stockers) stock, and tune the 3d tables.
if ANYONE checks your tune (via the ROM) they will see the stock boost tables... (unless they have the tephramod xml...
  #1016
tephra's Avatar
GUYS - for people where V7T6 isn't working, can they post their tephramod options? Maybe one of the options is breaking something...
Old Jun 27, 2009 | 12:42 AM
  #1017
fostytou's Avatar
EvoM Community Team
TTP.... are you sure you are using the correct immobilizer code location? The one that comes with the factory xml is not correct.
http://evoecu.logic.net/wiki/9653000...lacement_Notes
Sorry guys, unfortunately I can no longer test that rom since Derek totalled his car
Also, did you check valet/autovalet/valet RPM?
Old Jun 27, 2009 | 07:25 AM
  #1018
TTP Engineering's Avatar
We used both the disable and the with immob. I got the v5 to start however it almost seems that the launchmaps don't have their own injector scaling or something. Using 1050cc injectors.
Are the launchmaps using the high maps injector scaling or was this overlooked?
I tried putting my high maps in the launch maps and nothing.
I tried the out of the box settings and it started once.
I tried my high settings only under 100 load and nothing.
I went back to 96530006 and everything worked.
Old Jun 27, 2009 | 08:04 AM
  #1019
Using T6 and the supplied T6 bin file, here is what the tephramod options look like.
Old Jun 27, 2009 | 09:12 AM
  #1020
phenem's Avatar
Guys,
Everything worked for me, I am working on a USDM v7t6 patch for everyone. Give a little bit I want to make sure I test everything and don't want to release a bad patch like last time ;-)
~Zach
