TephraMOD V6 - testing!
Old Jun 29, 2009 | 05:35 PM
  #1051
phenem's Avatar
Yes you will need to change the Immob. Hex anytime you switch to a non UDSM ROM. For example the 96530006 is a EDM ROM so they have different Immob. hardware over there and different hex values. So that is why the change needs to be made when you run that ROM on a USDM vehicle.
Did I explain this correctly?
Old Jun 29, 2009 | 05:39 PM
  #1052
phenem's Avatar
Just confirmed all features of v7t6 to be working just as v7t5 was working for me. All features that I use and tested on my 2003 EVO8, boost, launch map, knock flash, drop boost on knock, and alt. maps.
Anyone else check anything else that we can check off the list?
Old Jun 29, 2009 | 06:18 PM
  #1053
nonschlont's Avatar
perfectly! thank you! The cloud is starting to clear.
Old Jun 29, 2009 | 08:16 PM
  #1054
laramie_05MR's Avatar
Orig. Rom 96940011 was running V5. Confirmed vehicle started with 96530706 V7t6. All features except valet of fresh ign. and afr confirmed.
Old Jun 29, 2009 | 11:54 PM
  #1055
nonschlont's Avatar
THESE FILES ARE THE LATEST v7t6 EDIT, FOR THE OLDER t5 EDIT PM ME!
Please use with caution! As Tephra says this is not 100% tested yet! Like Tephra I give no warranty ;-)
Download 1
Download 1 is File name: 96530706-v7t6-mods.zip
1. Immob. fixed to work on USDM cars
Download 2
Downloads 2 is File name: 96530706-v7t6-mods-phenem.zip
2. mrfred psi based boost implemented (just edit Tephra's gear dependant map)
3. OBD II Inspection ready for EVAP and EGR
4. Disabled EGR and EVAP
5. Disabled P0300 code
6. Disabled lean spool
7. Disabled boost cut
8. Disabled boost delay cut
Any USDM 8 should be able to run the second map without any trouble and pass emissions and everything, just copy in the standard stuff, immob, fuel, timing, etc...
If you are getting weird values for the Tephra Mod section please use the attached XML provided in my zip files and DELETE or MOVE other XML out of your ECUFlash directory and replace with the ones I included.
Let me know if there is anything else that needs done.
~Zach
Hey Zach, can u post up the base .xml required for this rom, PLEASE... TIA (2)
Old Jun 30, 2009 | 12:25 AM
  #1056
Asmodeus6's Avatar
The xml files are included in the downloads...
Old Jun 30, 2009 | 03:56 AM
  #1057
phenem's Avatar
Everything you need is included in the downloads I posted, the ROM, Tephra XML, and base XML.
Old Jun 30, 2009 | 08:07 AM
  #1058
derekste's Avatar
Originally Posted by fostytou
Sorry guys, unfortunately I can no longer test that rom since Derek totalled his car
perhaps I'll have another 96530006 capable vehicle before these bugs are confirmed/denied (unless logic beats me to it!)
Old Jun 30, 2009 | 09:24 AM
  #1059
evo505's Avatar
not find any mod for 22580006 (evo5 gsr)
Old Jun 30, 2009 | 07:10 PM
  #1060
nonschlont's Avatar
ok apparently, Im missing somethin here... 1 is the ROM, and the other 2 are the base and the 9653??? Sorry for the newbness, but I upload both .xmls, and copy the rom into ecuflash, and it tells me Unable to find parent metadata evo7base_20081101.... Everything is wack. "...." Am I even understanding this righ??? W/ the tephra v.6 and 015 rom, I had to upload my 015, base9, (that I set up), w/ the Tephra .xml in the same folder, and copy the tephra rom into ecuflash, and copy/paste everything over... TIA
Old Jun 30, 2009 | 08:58 PM
  #1061
Asmodeus6's Avatar
Read the post you quoted here.^ Your problem isn't noobness, it's reading comprehension. All the information and necessary files are in it.
Everything's been done for you.
You are missing the entire ship. Again, READ the post you quoted above.
Download 1 is tephra's V7.6 rom and xml file.
Download 2 is tephra's V7.6 rom with phenem's changes* and a modded xml file with Mr. Fred's patches incorporated thanks to Phenem. *He also went in and turned off EGR and EVAP etc in the rom.*
I... honestly... just read the post. We can't read it for you.
And do you have an Evo IX or VIII? You cannot use this rom on a IX.
Old Jun 30, 2009 | 09:04 PM
  #1062
nothere's Avatar
one more thing, the latest ecuflash version, it has whatever else you need.
Old Jun 30, 2009 | 10:31 PM
  #1063
nonschlont's Avatar
Im not sure if being sick is owning me, or reading just pwns me... I am aware this is for an EDM 8. And can/will be used for all/most of the Tephra 8 roms. (is my understanding) Im just trying to understand how to set up other roms for other vehicles, as I have not even connected to another car... I have a buddy w/ an 8 mr who has asked me to log his car w/ him, and I was trying to get a grasp on this, and possibly present this option to him. Obviously, I skipped over learning anything w/ other roms, till this point.
Edit: found the problem... The evo7base, Needs to have "_20081101" added to the end of the file name!
so looking thru the rom, I can not find the 3D "boost table",(dont think I missed it) 3D WGDC map is there, and not all of the normal baseline boost tables are not properly defined as well... I know those arent in use, just something I noticed...
I appreciate the help immensly!
Old Jul 1, 2009 | 04:32 AM
  #1064
phenem's Avatar
Adding that to the end of the evo7base.xml is a work around. What you really need is to upgrade to at least 1.41 or the latest version of ECUFlash. If you are not on the latest version that XML will not be there, hence why it can't find it. You renaming it was a temporary fix but I don't know what kind of other issues (maybe like you are having now) that it will present in the future. Upgrade to the latest version, copy in the provided XML and you should be good.
I am not knocking you are trying to be mean, but honestly this is testing and for people that really know their way around the ROM / XML enviornment. Based on your questions and some of the answers you are giving I can tell you really don't know your way around this type of testing. I would be very careful if I were you playing with other cars, other than your own. Honestly these types of questions are geared more towards when the final release is out. If you are still having trouble I would say to wait until the final release is out. Also I created a thread on modding a ROM / XML a long time ago, have you read through that? It explains a lot with screenshots and everything.
Link: https://www.evolutionm.net/forums/ec...ts-others.html
Old Jul 1, 2009 | 05:46 PM
  #1065
tephra's Avatar
ok hows the feedback on V6T7? any problems?
any weirdness?
mrfred has asked me todo a 88590015 - so I want to finalise the code base
