TephraMOD V6 - testing!
Old Jun 6, 2009 | 10:17 PM
  #901
roguck's Avatar
I have a late 04 EDM VIII (has the 96530006 ROM as standard) and I don't see the problem you are highlighting above in the quick logs I have done. It appears to be working fine to be honest.
I know this doesn't help you, sorry, but it does indicate that it may not be a problem in all vehicles.
Old Jun 6, 2009 | 10:30 PM
  #902
TTP Engineering's Avatar
Originally Posted by tephra
well the "min load ..." table controls when the WG is first acted upon.
but according to that table it should kick in about 86% load...
so I am not sure whats going on...
can you do a 3rd gear pull from like 1800rpm? i need to see the bottom end of the load + wgdc + rpm + tps
Is it just me or am I the only one wondering why duty cycle should even matter under 100 load where there is NO BOOST?
If the WGDC kicks in at 1.9 psi where the wastegate crack pressure is 11-13psi, what is the problem?
Old Jun 6, 2009 | 10:53 PM
  #903
dude's Avatar
I think I might have found the culprit.
It seems the BCS Re/Deactivation table is different between the 03 and 05 Evo's.
Here is the difference, 03 Evo value on top, 05 Evo value on bottom. I also notice that my WGDC goes to 100% right about 2250rpms and 120 load.
Bryan from GST noted it in this post here
Edit: the addresses for these 2 tables are also different. 2003 with 94170015 address in 1668, 2005 96530706 address is 1a68
Old Jun 7, 2009 | 02:24 AM
  #904
tephra's Avatar
oh cool
+1 to TTP there.. doesn't really matter when load < 120
Old Jun 7, 2009 | 05:58 AM
  #905
evo8dad's Avatar
can you email me your rom and the log?
and maybe mrfred's version of your rom..
Sure thing. PM me your email and I'll send it over for you to take a look.
Old Jun 7, 2009 | 06:27 AM
  #906
tephra's Avatar
its myforumname @ gmail.com
include your xml's for both too please
Old Jun 7, 2009 | 04:02 PM
  #907
fostytou's Avatar
EvoM Community Team
"Of course they were *****, Donny; they were threatening castration! Are we gonna split hairs here? Am I wrong?"
I don't think it should be a big issue, but I can see where you are coming from. The issue isn't serious, but we are making minor improvements so we might as well not make minor deficiencies
Good that you found the solution
Old Jun 7, 2009 | 06:01 PM
  #908
evo8dad's Avatar
Its pretty important to have the correct MAT scalings for SD
Old Jun 7, 2009 | 09:10 PM
  #909
dude's Avatar
The dude abides.
But seriously, I wasn't able to see if changing the BCS Re/Deactivation address/values gave me 100% WGDC like it should. Damn business travel and hampering my tuning.
Is there anyone else here running v7 coming from a 9417 rom? Or am I the only guy on my island on this...
Old Jun 8, 2009 | 04:41 AM
  #910
phenem's Avatar
Originally Posted by dude
The dude abides.
I am running it without any trouble, but then again I have a 03' VIII the bastard child of all EVO's!
Other's have said they have converted using my USDM distribution without any trouble as well. Some had minor hick-ups but mostly the problems of the user not transferring their data properly or deleting all the XML's so the data displays properly.
Old Jun 8, 2009 | 08:11 AM
  #911
linuxman51's Avatar
been working fine in my car, I just need to spend more time fine tuning things.
Old Jun 8, 2009 | 06:02 PM
  #912
dude's Avatar
I also have an 03. There was no xml to delete as I've never modded the 9653 rom, or the newer evo7base (dated). I even tried installing ecuflash in a new directory and got the same results.
So I'm assuming both of you have logged WGDC during a pull starting below 2250rpms and are absolutely sure that WGDC is 100% and not 0%???
Keep in mind this rom "works" in my car and I wouldn't call it "trouble"...it starts, runs, builds boost, changes timing and afr etc. It just doesn't work exactly how I want it to in regards to handling WGDC the same way as the 9417 ROM.
If you guys can empirically state that you do not have the same issues, please email me your xml and rom image. christopher.byrne at gmail and I will install ecuflash in a new directory, replace the xml, load your map and change nothing other than the immob code and injector settings and see if I was the source of the error.
Old Jun 8, 2009 | 06:56 PM
  #913
phenem's Avatar
Did you add the appropriate XML that Tephra included in his release?
Are you using my modded version or Tephra's version and you are modding it yourself? If you are modding it yourself download my version and try that too, maybe there is something you are not copying over.
Make sure you copy in the appropriate XML that Tephra includes because you do have to delete any previous v6 or v7 XML that you might have in your ECUFlash directory.
I have 100% confirmed WGDC working perfectly as expected. If you look a few posts up I was having issues but it was my min load for WGDC map that was the culprit.
Old Jun 8, 2009 | 07:43 PM
  #914
linuxman51's Avatar
Sorry, I use an EBC. I speak to the continued ability for me to walk out to my car at 7am and drive to work. My requirements are relatively low in comparison to others, but in the ten years I've been messing with cars I've also found that simplicity saves a lot.
Old Jun 8, 2009 | 07:56 PM
  #915
EvoDan2004's Avatar
sorry to drift off on this v6 topic but i have a quick question. i just finished the v5.10 for my 2003 evo8 ''rom 94170015'' is this v6 available for this map and is it bug free like the v5.10 and lastly do i have to do this all over again. hahah.thanks guys for the help
