TephraMOD V6 - testing!
Old Jun 9, 2009 | 05:59 PM
  #931
phenem's Avatar
Originally Posted by tephra
Maybe just do it that way then.
I'll release the mini-xml in the zip, and then on the 1st post we can link to a full xml that ppl can use if they want to (or are having problems)
Perfect! I can provide the entire XML when you need it. Just let me know.
Old Jun 10, 2009 | 08:51 AM
  #932
derekste's Avatar
if you could put it up on the wiki before then, I'd appreciate it. I've made so many changes to my 96530006 XML that I have no idea what is accurate and current anymore. Would be nice to start anew.
Old Jun 10, 2009 | 11:19 AM
  #933
phenem's Avatar
I will sit down later tonight and re-organize it and create the XML and post it up. Watch this post for updates...
Old Jun 10, 2009 | 10:42 PM
  #934
Ludo's Avatar
88840017 same as 88840016?
Thanks
Old Jun 10, 2009 | 10:43 PM
  #935
tephra's Avatar
You can upgrade from 88840016 to 88840017 yes...
Old Jun 10, 2009 | 11:03 PM
  #936
Ludo's Avatar
Thanks,
I can replace 88840016 by 88840617 in my Evo IX USDM?
Old Jun 11, 2009 | 04:40 AM
  #937
mlocatel's Avatar
if you had 88840016 then yes.
I made the same with my Evo IX
BR
mlocatel
Old Jun 11, 2009 | 07:31 AM
  #938
Ludo's Avatar
I test this evening or tomorrow
Ludo
Old Jun 11, 2009 | 12:08 PM
  #939
AIK's Avatar
AIK
I have some questions.
1. What is the oldest Equflash version which correct work with V6-7?
2.MAF IAT WGDC correction - good idea, but when the weather is changing boost changing too (i say about load-based boost control) if target is the same. May be we need have MAF IAT target correction ?
3. Anybody try to use V6-7 and weather MrFred mods in common ? Does it work correct?
Sorry if anybody asked already the same questions...
Old Jun 11, 2009 | 08:19 PM
  #940
fostytou's Avatar
EvoM Community Team
1. The rom is independent of ECUFlash version. The include statments specifically should work as far back as base files have been used.
2. Why would you want to reduce the target? The goal here is to keep the tune the same (same target) while getting rid of weather related spikes.
3.Some of them. Direct boost and narrowband sim seem to work fine. Others have posted in the thread. So far no direct incompatibilities found.
4. You aren't sorry if you asked
Old Jun 12, 2009 | 12:05 PM
  #941
ixbreaker's Avatar
ok something very strange happened. Version 6 for me was working with my 15rom. i have a 2006 USDM,evo. Everything tested out fine for about a couple weeks. Then this morning it wouldn't start! I thought my battery was dead because it's about time, but it still didn't start after jumping it with another car. You could hear the starter barely turning over for a fraction of a second and it would just seize.
So after all failed attempts I was about to flash back the old Version 5, but i got this crazy idea maybe valet mode was somehow activated. So i hold down the gas peddle for about 10 seconds or a little more and guess what. It starts! wtf just happen!?! I know i set that valet mode to 0. I even double checked the rom inside the car and it's 0. This was very very random.
I then tryed the opposite of activating valet mode but it just keeps starting now.
The only mods I have checked are:
Flash cel on knock
NLTS
MAP Averaging
Manifold Temperature
as of that last occurence no problems whatsoever for about 3 starts in the past couple of days. But, i'm worried it might happen again.
Old Jun 12, 2009 | 03:51 PM
  #942
nothere's Avatar
I'll bet you could have rubbed your tummy instead of doing the valet shuffle and had the same effect.
iow you have a mechanical issue unrelated to the ecu.
Old Jun 12, 2009 | 06:19 PM
  #943
tephra's Avatar
ixb - well if you have valet disabled then doing the valet shuffle wont change anything.
v7 cleans up a lot of that code so hopefully once its out proper you wont have to worry
Old Jun 12, 2009 | 10:27 PM
  #944
kaj's Avatar
kaj
did anyone ask for a 88590013 version yet??
Old Jun 13, 2009 | 01:30 AM
  #945
tephra's Avatar
upgrade to 88590015
