TephraMOD V6 - testing!
-You never *need* to copy your MUT Table. It is only for logging.
-To use HP/TQ with one byte load you just need to change the formula in evoscan to reference 1 byte load rather than something else. Better yet would be to use the spreadsheet based virtual dyno room posted in this forum.
-If changing the formula didn't work, you probably did it wrong...
Edit: I think when I changed the formula, changed it to "Load1Byte" when it should probobly be "LoadMUT1Byte" can some1 confirm this for me, or I'll just have to try it ... lol
and I do use the VDR as well. Thanks J.O.T.
Which Boost tables ?
I'm using Phenom's prepared ROM (2nd DL) on an 03' with good results. However I cannot seem to get past WG pressure 14-15 PSI with a Tactrix (Prodrive)BCS with just swapping over my maps and starting it up.
Is it as simple as filling in the 3D tables that are zero'd out in Phenom's ROM, do I use the 2D tables for the single BCS that have values in them already, or are there more set up steps I need to research?
Attachment 1: 3D tables in the mods section
attachment 2: 2D tables under single BCS
I do have a JDM 3 bar and it is logging correctly, is this included in the loop in this metheod of boost control?
Many thanks to all who have contributed to this, and to Phenom for packaging up all the goods in one ROM!
Does anybody know if the 96530706 (modified 96530006) rom has the intercooler sprayer code still in it and if so what are the definitions to control it? Also, in theory, if I make my "time to activate alt maps" 0ms and I give the alt map 5v input the ecu will switch over instantaneously assuming it is above the load threshold?
thanks,
dan
thanks,
dan
There is a bug with 0ms activation - use 1 step up from 0ms.. ill fix this b4 V7 release
It will basically be instant
ICS should still be available
Can you re-test the AFR safety? especially the new timer part
ICS should be there but the maps are not defined in ECUFlash like they are for the 94170015 and older ROMs. Anyone have a quick definition of them handy?
The question for the intercooler sprayer and map switching is so that I can use the ecu to turn on the methanol and once my sensor picks up methanol flow to then switch to alternate maps to then provide the proper AFR. This is for the evo 8 ecu.
Yes I can test. Do you wish to have it tested for evo 9 (I can do the evo 9 this weekend) or evo 8 (the evo 8 won't be till the following weekend). In case you haven't caught on, the evo 8 ecu is running in my DSM so I can test both.
Thank you sir!
I changed the g/rev formula (I believe) that referenced "2byteload" and changed it to "1ByteLoad" and nada. Is this not correct, or is there more to it? And of course I had 1ByteLoad above all of the g/rev hp and tq stuff... I'll give it another shot.
Just look in evoscan at other definitions that are referencing other logged items to get an idea of how it works. It's not magic
thanks but it wasn't those bits I was thinking of it was just the resolution bits that relate to the WGDC correction with the load based boost.
here's the link;
https://www.evolutionm.net/forums/ec...trol-mods.html
the main interest is changing the WGDCC.
Richard
here's the link;
Richard
Have been switched to 96530706 V7T6 from 97470001 (Tuned).
Now have CEL flashing all the time i press throttle more that a half. Boost is 0.7 bar (A'pexi AVCR). What should i do?
LOL i've understand that i must to stop the detonation ... But can't understand how stock V7T6 rom have so many knocks, and my tuned one (More agressive afr) is dont have one, or very little...
Transfer over your maps. I don't know why you would want to even drive the car like that.
If the knock is phantom, so to speak, you could try adjusting the knock load MAP under the Knock tables in the ROM but, again you need to confirm that it is in fact phantom knock.
