TephraMOD V6 - testing!
Old Apr 13, 2009 | 07:08 PM
  #391
tephra's Avatar
ok - be a day or two
Old Apr 13, 2009 | 07:13 PM
  #392
Jumperalex's Avatar
Originally Posted by tephra
thanks gearhead, so to recap:
For 96530006:
- you can just plug in a 3bar sensor and not have to change the ECU scalings for MAP sensor (since the ECU isn't aware of the MAP sensor)
- you CAN still do the psi based mod - follow MrFreds instructions for doing so..
Sound right?
woah ... sorry if this isn't the right place, feel free to point me to the appropriate thread if this has already been covered, but are you telling me 9417 uses the 1 bar MAP sensor but 9653 doesn't use anything at all? So is the MAP sensor pretty much US only emissions related then? And is that going to impact OBD2 e-check or are can we handle that via periphery?
Old Apr 13, 2009 | 07:15 PM
  #393
tephra's Avatar
yeah i think it's only for emissions.
Zach - can you check out the difference between the ROM's for emissions readyness?
Old Apr 13, 2009 | 07:18 PM
  #394
Jumperalex's Avatar
Yeah cause that will be a big non-starter for most US Evo's I would assume :O
Old Apr 13, 2009 | 07:43 PM
  #395
phenem's Avatar
Will do, I will report back tomorrow...
Old Apr 13, 2009 | 07:46 PM
  #396
GST Motorsports's Avatar
ok I will work on a V7 96530006 and post up - probably wont work first go thou
I love you long time!
Did I see a mention of map switching without a physical switch, by a pedal?
Old Apr 13, 2009 | 07:53 PM
  #397
Jack_of_Trades's Avatar
Yep, though the car needs to be shut off to do so, so if the intent is for failsafe map switching with alky injection and stuff you'll still need to use the ADC0F input.
Old Apr 13, 2009 | 08:00 PM
  #398
tephra's Avatar
yeah pedal switching... just for the guys that don't want a switch and can live without valet
Old Apr 13, 2009 | 08:15 PM
  #399
How about map switching with pedal and failsafe with ADC0F input?
Old Apr 13, 2009 | 08:46 PM
  #400
fixem2's Avatar
Jumperalex, I used 96530006 to replace 96940011 and have no issues with OBD and as Gear Head stated. Direct Boost and MAP sensor reading work like a charm.
Old Apr 13, 2009 | 08:50 PM
  #401
Jumperalex's Avatar
right but what about switching from 9417? And have you done an e-check with it?
I do hear ya though about direct boost and map sensor reading.
Old Apr 13, 2009 | 08:55 PM
  #402
fixem2's Avatar
No echeck. I used Scan tech and so all the same checks and answers with both ROMS.
Old Apr 13, 2009 | 08:56 PM
  #403
THUB's Avatar
I'll be trying the 965 rom switch on my car tomorrow after work. I have to do a resistor mod for my rear O2 sensor, but after I do that I'll also try it for an official emissions test too. sorry to take this off topic but does anybody remember off hand which resistor works correctly?
Old Apr 14, 2009 | 12:17 AM
  #404
tephra's Avatar
ok testers - can you let me know if you find the 1% wgdc accuracy worthwhile?
I am thinking of dumping that section of code.
It add's a little bit of complexity and is slower than the original code - so if it's not noticable or anything then I might dump it :|
Old Apr 14, 2009 | 12:54 AM
  #405
mlocatel's Avatar
Hello Tephra
for me it's not.
Basically there is a minor difference between a 1% and 2% accuracy.
If you can get the code to work faster, that's a small price to pay
