TephraMOD V6 - testing!
Old Apr 14, 2009 | 06:15 PM
  #421
phenem's Avatar
Originally Posted by tephra
V7 will require a lot of testing since I can't do any of the testing myself anymore. I expect the first version not to work properly :|
OK, well let me know when you need help with testing, my car sits all the time, weekend grocery getter so I don't mind testing when I can...
Old Apr 14, 2009 | 06:58 PM
  #422
l2r99gst's Avatar
tephra,
I was thinking about ways to switch maps, since you are going to now use the throttle for v7, I think, in lieu of the valet.
What about using the aircon switch (came to my mind from the aircon thread just posted recently). The aircon is something that is universal to all ECUs and definitely used as an input to the ECU, so I would think if it is possible to use, it may be worthwhile?
Can something be coded like: activate aircon switch x number of times within y number of seconds? For example, turn aircon on/off 3 times in 2 seconds or something like that?
Old Apr 14, 2009 | 07:00 PM
  #423
tephra's Avatar
Hi Eric,
I have thought of the A/C switch b4.
Unfortunately I dont think the switch is wired into the ECU.
I think:
1) the compressor on/off signal is wired in as an INPUT
2) the compressor override is wired in as an OUTPUT
Know what I mean?
Old Apr 14, 2009 | 07:10 PM
  #424
logic's Avatar
According to RRE and MLR, either pin 8 (A/C relay) or pin 24 (A/C control unit) ought to do the trick on an Evo VIII, no? (Pin 32 appears to be the fan relay.)
For the non-USDM models and the IX, it looks like pins 20, 30, 31, and 65 are involved?
(Ah, I see what you mean, you might be right about the switch itself not being wired in. Shame.)
Old Apr 14, 2009 | 07:43 PM
  #425
l2r99gst's Avatar
From the RRE pinout diagram, it says AC switch is pin 45. I'll look through the service manual to see if I can see anything.
I'm not sure if I follow you exactly, tephra, but I'm not that good with the ECU inputs, etc. I just figured since some tables are based on AC on/off that the AC was an input that the ECU uses (example, idle tables).
Old Apr 14, 2009 | 07:45 PM
  #426
tephra's Avatar
ok you have climate control yes?
so the compressor clicks on and off all the time.
I think the ECU can see when the compressor is ON/OFF which is DIFFERENT to when the switch is ON/OFF.
I think you will find MUT9A logs when the compressor is on/off (as well as other bits) try logging it and turn the A/C - then wait for the A/C to turn the compressor of (with the switch still on) and see if MUT9A changes...
Old Apr 14, 2009 | 07:49 PM
  #427
l2r99gst's Avatar
I see what you're saying.
I just took a quick look at some circuit diagrams and they list the AC switch as an input to the ECU. I'm not sure what they are referring to as the 'AC switch' though.
For example, the inputs to control the fan module are:
1. ac switch
2. coolant temp
3. vehicle speed
So, that 'ac switch' is an input. If that is just the condensor on/off input as you are suggesting, then I agree it won't work. But, if the actual switch is an input, that would be good.
Old Apr 14, 2009 | 07:53 PM
  #428
tephra's Avatar
Do me a favour -
Log MUT9A.
I think it was MUT9A...
Then try a few different things with the A/C switch/system
Old Apr 14, 2009 | 07:54 PM
  #429
l2r99gst's Avatar
OK, no problem. I'm going to look through all of the circuit diagrams first to see if I find anything of interest.
Old Apr 14, 2009 | 07:55 PM
  #430
tephra's Avatar
ok
Old Apr 14, 2009 | 08:59 PM
  #431
tephra's Avatar
does someone with 90550001 want to check to see if 96530006 works on their ECU as well.
i suspect it will just fine - be good if it does - 1 less ROMID to maintain
Old Apr 14, 2009 | 09:49 PM
  #432
recompile's Avatar
Originally Posted by GST Motorsports
I can see the alternate BDEL and BWGDC 3D tables just fine?
They both have 0's in them by default so that is probably why you are getting BCLO+0 and 0 WGDC. Sounds like your def is messed up and those tables aren't showing for you.
Thanks.
It turns out the XML was bad in the initial post (back when the thread was first started) it looks like he's fixed it since then.
Old Apr 15, 2009 | 12:10 AM
  #433
tephra's Avatar
ok next question.
at the moment I have 2 numbers for knockcel -
High Knock Boost Drop time
CEL on Knock flash time
Any objection to making these the "same"?
Old Apr 15, 2009 | 03:42 AM
  #434
cossie1's Avatar
It will work, but not very well, as I tried it in the past when I wanted to see if the 7 ecu would work with launch control.
iirc, 8 and 22 need switching around to get the car to fire up, and then the car doesn't run too well.
Also we would loose the sas control (pops and bangs).
Old Apr 15, 2009 | 05:15 AM
  #435
tephra's Avatar
ok i'll keep 90550001
