Links to jcsbanks' Speed Density patches
Old Jun 7, 2009 | 02:23 PM
  #121
mrfred's Avatar
Looks like the SD load is not getting written to the master load. I need to investigate further. I'll report back in a little while.
Old Jun 7, 2009 | 02:55 PM
  #122
mrfred's Avatar
Can you modify the MUT table to read FFFF89B4 and FFFF89B8? They are two-byte values. Then get another log with and without the MAF connected. For your next logs, please attach to the message as text files. Should take care of the column alignment issue.
Old Jun 7, 2009 | 03:05 PM
  #123
l2r99gst's Avatar
Do you just want FFFF89B4 and FFFF89B8 or B4/B5 and B8/B9?
Old Jun 7, 2009 | 03:23 PM
  #124
mrfred's Avatar
Setup up for two-byte, so B4/B5 and B8/B9.
Old Jun 7, 2009 | 03:53 PM
  #125
l2r99gst's Avatar
Here you go...note that the car wasn't warmed up yet. I just flashed the SD ROM, waited a minute and ran the log. Blipped the throttle a couple times with MAF connected, kept car running, disconnected MAF, got back in and blipped the throttle again a couple times.
It looks like those 2-byte variables are increasing fine, as load should. However, the 160load is not.
Here's the log:
File Type: txt
Old Jun 7, 2009 | 04:30 PM
  #126
mrfred's Avatar
ok, now please add two more 2-byte values to your logs:
FFFF89AC/D
FFFF89C0/1
Old Jun 7, 2009 | 04:45 PM
  #127
l2r99gst's Avatar
Do you have any more that you want me to log, so that I can get it all in this one log? I think this will be the last one that I have time to get to today, so if possible I it would be great to get you all the info that you need. (Since I'm going away this week, I don't know if I will have time the next two days to do any further testing and I know others are eager to get this.)
I always flash my car back to my working ROM, in case I need my car, so every log is 2 flashes...I was also maybe hoping to save a few trips/flashes and try to capure everything you need in one log.
Eric
Old Jun 7, 2009 | 04:49 PM
  #128
mrfred's Avatar
I always flash my car back to my working ROM, in case I need my car, so every log is 2 flashes...I was maybe hoping to save a few trips/flashes and try to capure everything you need in one log.
Eric
I don't know what else to look for until I see the response of these two RAM variables, so we'll have to do with it for now.
Old Jun 7, 2009 | 04:52 PM
  #129
l2r99gst's Avatar
No problem....coming up. Give me about 10-20 minutes.
Old Jun 7, 2009 | 05:26 PM
  #130
l2r99gst's Avatar
Looks like 89ac/d isn't responding with the maf unplugged.
Here's the log:
File Type: txt
Old Jun 7, 2009 | 06:34 PM
  #131
mrfred's Avatar
Here's the log:
If you have time tonight, please email to me the SD ROM that you're using.
Old Jun 7, 2009 | 06:44 PM
  #132
l2r99gst's Avatar
Sent.
Old Jun 7, 2009 | 08:42 PM
  #133
mrfred's Avatar
Sent.
I found the problem. I hate to do this to you, but I have to send you a fresh v7 SD ROM. You'll have to copy over all your tables again.
Before I release it, I'm going to wait until Eric has a chance to try it.
Old Jun 8, 2009 | 10:42 PM
  #134
mrfred's Avatar
The issue Eric was having with the 96530006 SD patch has been resolved, so I have added the 96530006 SD patch to the first post in this thread. I have also added some additional instructions for installing the patch in the second post in the thread.
Old Jun 9, 2009 | 01:00 AM
  #135
GotWheelHop's Avatar
Oh wow....bet the 05 guys are gonna go nuts with this one.
Nice job, M.
