Legnum VR-4 Def File
Old Mar 19, 2009 | 01:38 AM
BarryC's Avatar
the boost limit table seems to be off tried looking around the surrounding area
to see if I could find it no luck
Old Mar 19, 2009 | 02:27 AM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Originally Posted by merlin.oz
Results so far. Anything with a * prefix is dodgy.
Change the .txt back to .xml after downloading.
Marlin you have it wrong in base it should look like this
Code:
	<table name="MUT Table" category="MUT" address="2fad0" type="3D" level="2" scaling="Hex16">
		<table name="X" elements="16">
			<data>0</data>
			<data>1</data>
			<data>2</data>
			<data>3</data>
			<data>4</data>
			<data>5</data>
			<data>6</data>
			<data>7</data>
			<data>8</data>
			<data>9</data>
			<data>A</data>
			<data>B</data>
			<data>C</data>
			<data>D</data>
			<data>E</data>
			<data>F</data>
		</table>
		<table name="Y" elements="16">
			<data>MUT0X</data>
			<data>MUT1X</data>
			<data>MUT2X</data>
			<data>MUT3X</data>
			<data>MUT4X</data>
			<data>MUT5X</data>
			<data>MUT6X</data>
			<data>MUT7X</data>
			<data>MUT8X</data>
			<data>MUT9X</data>
			<data>MUTAX</data>
			<data>MUTBX</data>
			<data>MUTCX</data>
			<data>MUTDX</data>
			<data>MUTEX</data>
			<data>MUTFX</data>
		</table>
	</table>
Old Mar 19, 2009 | 05:03 AM
cossie1's Avatar
Originally Posted by acamus
Periphery bits for H8/500 seem to be
Periphery 00: 0x262
Periphery 0: 0x272
Periphery 1: 0x282
Periphery 2: 0x292
Periphery 3: 0x2A2
Are these Ecuflash address's ?
As they don't work with Evo 5/6 roms if they are
Old Mar 19, 2009 | 05:09 AM
acamus's Avatar
add 0x10000 loading offset, i.e. 0x10262
sorry for that I was writing whole thing as raw hex file,
all addresses above are raw without the offset.
correct xml input is then here
Old Mar 19, 2009 | 08:11 AM
cossie1's Avatar
Nice work
Old Mar 27, 2009 | 01:29 AM
kc427's Avatar
1FAD0 seems to be a mut table 16 bit values
(e.g. MUT_06(ignition) = 0xF243)
It seems same MUT table address is valid for all H8/5xx in my collection
23490007 EM2349 ?? EVO5 RS BC
21810022 EM2181 00 ECLIPSE GT MT FED
23500002 EM2350 99 Mirage
25680002 EM2568 00 Mirage
23810003 EM2428 99 Galant VR4
20030011 EM2005 98 Legnum VR4
20030013 EM2004 ?? Legnum VR4
ROMID @ 0x21a
I read my 98 Galant VR4 rom, and the ROMID @0x021A is:
20030011 EM2004 98 Galant VR4
Old Mar 27, 2009 | 08:04 AM
Mattjin's Avatar
Some maps to keep you busy. Add to the Base xml
<table name="Warmup Retard Control" category="Timing" address="11fae" type="2D" level="3" scaling="Percent255">
<table name="Engine Temp" address="2d0f4" type="X Axis" elements="8" scaling="Temp"/>
</table>
<table name="Timing Trim vs Engine Temp" category="Timing" address="11f7c" type="2D" level="2" scaling="Enrich">
<table name="Engine Temp" address="2d090" type="X Axis" elements="8" scaling="Temp"/>
</table>
<table name="Timing Trim vs Air Temp" category="Timing" address="11f88" type="2D" level="4" scaling="Enrich">
<table name="Air Temp" address="2d10a" type="X Axis" elements="7" scaling="Temp"/>
</table>
<table name="Target Idle RPM - Neutral" category="Idle" address="12004" type="2D" level="4" scaling="RPM8">
</table>
<table name="Target Idle RPM - Drive" category="Idle" address="12010" type="2D" level="4" scaling="RPM8">
</table>
<table name="ISCV Initial Steps #1" category="Idle" address="1201c" type="2D" level="4" scaling="ISCVSteps">
</table>
<table name="Decel Fuel Cut Resume RPM Offset" category="Fuel" address="1147a" type="2D" level="2" scaling="RPM8">
</table>
<table name="Fuel Primer Enrich" category="Fuel" address="1155c" type="2D" level="2" scaling="uint8">
<table name="Engine Temp" address="2d0a6" type="X Axis" elements="9" scaling="Temp"/>
</table>
<table name="Limp Mode Table" category="Fuel" address="1157b" type="3D" level="2" swapxy="true" scaling="uint8">
<table name="TPS" address="2d07c" type="X Axis" elements="7" scaling="Volts16"/>
<table name="Engine Speed" address="2d06c" type="Y Axis" elements="5" scaling="RPM"/>
</table>
Double check them. I just found them quickly and they are completely untested.
richardjh
Jul 28, 2017 03:49 PM
Hiboost
15
Jan 10, 2016 10:15 PM
mrfred
Oct 2, 2015 12:41 AM
PPM
Apr 2, 2015 09:35 AM
NOMIEZVR4
Oct 26, 2009 10:36 PM
