HELP... my car stalls at stop
Old Mar 13, 2009 | 05:33 AM
El Boricua's Avatar
Unhappy HELP... my car stalls at stop
Need some help....
I re-tuned my car to solve some issues after installing PTE 1000cc injectors with my 35R setup, and VTA BOV... I know that for the 2003 EVO (my car) the VTA is a real issue, but I kind of fine tune it except for the problem described bellow....
"(this is a copy of some other guy post, but his problem was with the AC... I have no problem with my AC)"
Here is what happens, car runs fine at cruising speeds ,,,
However, sometimes when I press clutch in and come to a stop the rpms drop to low and it stalls out... sometimes will making slow turns off roads which isn't good cuz the power steering.
If I ease at a light and stay in gear until I come to almost a complete stop its good, it seems it does it mostly when I see a red light push in clutch and quickly stop or when I do this and make a turn.
if anyone can point me in the direction in ecu flash to correct this I'd really be appreciate it.
Thanks...
Old Mar 13, 2009 | 05:45 AM
timmiii's Avatar
IF you're running your stock MAF sensor then you'll have that problem when using the VTA BOV.
Old Mar 13, 2009 | 06:01 AM
El Boricua's Avatar
Yes I'm still using stock MAF........
Is there any work around..?
Thanks,
Old Mar 13, 2009 | 06:09 AM
evo082006's Avatar
You will need to go to a GM blowthrough MAF with MAF translator, or get a standalone ECU. There is some talk circulating on this forum about Speed Density with the stock ECU. I requires a JDM 3 bar MAP sensor, GM IAT sensor put in your UICP, and some rom mods. Here is the link..
https://www.evolutionm.net/forums/ec...y-patches.html
As for now, it will continue to stall until you recirculate the blowoff valve..
Old Mar 13, 2009 | 06:24 AM
darkside4G63's Avatar
^ what he said. man its annoying when mine dies. i had mine VTA and it died all the time when coming to a stop. i recirced it and it still does it every now and then.
Old Mar 13, 2009 | 06:25 AM
El Boricua's Avatar
That's exactly what I didn't wanted to hear (know)..!!!
Old Mar 13, 2009 | 10:13 AM
evoredy's Avatar
what ecu does your car have if you know? i think its usdm/but not sure. let me know. i recently removed my MAP to MAF clipping patches, but they do work/does not require another MAP/IAT/etc.
i have a friend with a stock turbo'd 8 with all sorts of ic piping/intake/and a VTA HKS which he insists on running. I applied my patch to his car and it actually doesn't stall at all/runs great.
i would suggest a mechanical fix first, then go to other options.
Old Mar 13, 2009 | 10:36 AM
mplspilot's Avatar
Increase ICSV steps by 5-7 in 77C and 82C cells in the table used for when A/C is off.
Old Mar 13, 2009 | 10:48 AM
fostytou's Avatar
EvoM Community Team
If you are moving the car should be in gear anyway
I believe there is also a "target idle while in gear" that you may be able to modify or make fit via conditions.
Old Mar 13, 2009 | 11:12 AM
El Boricua's Avatar
Hey now that you mention, I went out to lunch and turn the A/C on (was hot outside)..... and for my surprise, it doesn't do it that much with the A/C on..!!!
So I will try this fix and let you know later.
Thanks a lot.
Old Mar 13, 2009 | 11:35 AM
El Boricua's Avatar
I must say that I have a USDM ECU, since every new car here in PR comes directly from the US (nowhere else).
Your help is must welcome.
Thanks,
Old Mar 13, 2009 | 12:36 PM
Fast_Freddie's Avatar
Veteran: Navy
You can also try this... https://www.evolutionm.net/forums/ev...k-install.html
Old Mar 13, 2009 | 01:09 PM
El Boricua's Avatar
Well searching in the backup file of my missing brain I just recall that I have the S-AFC2 installed... I will try to set the Deceleration Air Flow Correction to see what happens..!!
Thanks for the very good info...
Old Mar 13, 2009 | 01:42 PM
X91EVO's Avatar
Registered User
I have a recirculated greddy bov (with proper fitting) and it still stalls always!! stock bov is best way to go without problems imo
Old Mar 13, 2009 | 09:20 PM
DOUGLAS's Avatar
I have been having the exact same problem.....and it has become worse and worse.....if I quickly take a load off of the engine rpms will drop way down and almost stall.....im working on getting a tactric cable and doing some logs to see whats going on......im in need of a tune
