EvoScan: Saving Injector Scaling?
Old Mar 18, 2009 | 10:18 PM
MasterNater's Avatar
Does anyone happen to know if there's a trick to getting EvoScan to save the injector scaling entry? The first few times I used EvoScan, I had to manually put in my scaling every time. Then all of a sudden, it stayed where I put it even after restarting the program. Now I need to change it every time again. Is there some kind of magic trick I'm missing?
Old Mar 18, 2009 | 10:26 PM
tephra's Avatar
dunno - you can probably put it into the savedsettings file.
what are you using it for? i hope not 'calculated load'
Old Mar 19, 2009 | 07:29 AM
I thought about that but like I stated before, EvoScan just decided to keep my scaling setting all of a sudden and I didn't know why. I guess it's not that big of a deal having to enter the value every time, just a little annoying.
Why am I using the injector scaling or EvoScan in general? Because Mellon is in the process of tuning my car.
Old Mar 19, 2009 | 03:13 PM
tephra's Avatar
no what are you using the scaling in evoscan for?
u dont really need to use it...
Old Mar 19, 2009 | 04:03 PM
GST Motorsports's Avatar
The only reason to use the injector scaling in Mitsulogger or Evoscan is to get "correct" calculated load with larger than stock injectors.
To log true load, you need to log 2byteload.
Fast_Freddie
Oct 30, 2023 01:56 AM
lncrphish
Lancer Engine Management / Tuning Forums
15
Aug 3, 2010 06:48 AM
03lances
Nov 20, 2009 12:19 PM
9sec9
Jun 7, 2007 09:03 AM
jrsimon27
Apr 27, 2007 11:18 AM
