Tuning issues
Tuning issues
Okay, I am having some other issues and I have decided to post it here in a new thread since it isn't related to the fuel pump issue I had.
94 Octane, Ported Ex Mani, o2 Housing, LICP, Open Amsoil Filter, TBE no cat, Hallman MBC
I don't really know how to explain it but here is a copy of the log.
I know I need to fix the AFR's as this was the first AFR change I made since having AFR's in the 10's.
What would cause the load to go so low? Is it that I don't have scaling above 300? I understand that I should not be over 300 on the mods I have and I will be doing a boost leak test shortly, but was curious what would cause the log above.
Yea, I understand I am hitting different parts of my map, but why did it go to 3.6, 8.4, and 4.8?
The afr values are from my WBo2.
Columns are as follows:
TPS RPM Timing JDMMap Load WBo2 Knock
I rescaled the map to add 320 load in and did a quick log today and got the same wierd issue around the same RPM point. Any other ideas on what would cause the load to drop like that consistently run after run? It is way too lean and really throwing off the ability to tune the car with a nice smooth AFR curve.
you need to change the 2byte to 1byte load factor in your tephra mods to something higher like 1.3 and also do the same for your evoscan formula. I think its set to 1.2 by default which can only read a maximum load of 306. Changing to 1.3 allows you to log up to ~332
That was spot on. Thanks for the info.
