Tephra, can you tell us what address to map switch
Hi Tephra,
I tried to adjust bit 6 of FFFF8400 with a button in my app but it won't take the changes and switch maps.
Which bit of which address should I change?
Some people have your patch (+ my live mapping) and want to switch maps but don't have ICS or switch, but want to live map.
Cheers,
John
Cheers,
John
Hey John,
From memory there isn't a specific bit to set which map. It's just a countdown loop which set of conditions need to be met each ECU loop... if not the countdown gets reset... if the countdown gets to 0 then the maps swap...
I guess you could set the countdown to 0 and then next loop it should set to altmap.
Which version of TephraMOD are you using? 5.10 or 6?
5.10
How could I overwhelm the ICS variable though as well as kill the counter?
MR Turco, doesn't really look like this is feasible as the code hasn't been written in a way we can just poke a memory address to make it switch.
No problem, it is a good excuse to finally build in the switch for switching maps.
