96530006 Live Map download
Old Aug 25, 2009 | 02:41 AM
  #151
tephra's Avatar
tried disabling the immob code totally?
Old Aug 25, 2009 | 04:20 AM
  #152
YaroRS's Avatar
Do you mean periphery (FAA) bits and disable immobiliser ? I disabled it and it didnt work.
Old Aug 25, 2009 | 04:21 AM
  #153
tephra's Avatar
ok
are you using my tephramods?
if so - try raising the valet rpm to 2500 and reflash and retest...
Old Aug 25, 2009 | 06:05 AM
  #154
YaroRS's Avatar
thanks a lot, sorted. The problem was with valet RPM. But the other problem stays, it doesnt want to livemap ?!? Enabled ICS AUTO switch for alt maps, but it still doesnt log. Any suggestions ?
Old Aug 26, 2009 | 12:12 PM
  #155
roger smith's Avatar
What do you mean by 'doesn't want to livemap'? It won't log? Or it won't write to RAM?
In order to write to ram you have to be logging.
ROM address : 00 03 8b 00
RAM address : ff ff a0 00
bytes to copy : - - 08 00
logging address : ff ff a7 40
RAM fuel address : a0 4d
RAM ignition : a2 cd
Those are addresses for this rom, 96530006
Old Aug 27, 2009 | 04:21 AM
  #156
YaroRS's Avatar
tried everyting I could think of, but it says unable to open port.
Old Aug 27, 2009 | 12:34 PM
  #157
jcsbanks said this about someone having the same problem I think
"It can't open a port to the first FTDI device on your system. "
Do you have other USB devices plugged in when you are trying this?
Maybe try plugging your cable into a different port.
Also maybe try this...
http://www.ftdichip.com/Drivers/VCP.htm
I'm not knowledgable with hardware stuff so these are just guesses (things I would try myself)
Old Sep 7, 2009 | 01:10 PM
  #158
golruss's Avatar
Originally Posted by fjo_newport
I wanted to update this thread, ever since I fixed my idle a few days ago I have not had any issues with the DMA failing and the ECU resetting. It seemed to happen any time I threw a check engine light, this just proves that this is what was going on. I hope this helps trouble shoot the issue.
Thanks again guys!
How did you fix your idle problem?
tephra
Dec 26, 2023 01:11 PM
ziad
Feb 5, 2022 08:27 PM
jcsbanks
Jun 9, 2011 11:45 AM
logic
Nov 27, 2009 08:56 AM
jcsbanks
Mar 28, 2009 07:33 AM
