Suggestion need on my 4th gear pull
Old Mar 30, 2009 | 02:58 PM
G20's Avatar
G20
Originally Posted by rolly1818
ur fuel map needs some redoing.
for some reason i cannot see your logs or get em off the website
feel free to PM me and i can have a look.
click on the Evo Scan datalog... file doesn't do download for you? It did for me but if it's not for your case then I'll be sending an PM soon. Thanks for looking.
Old Mar 30, 2009 | 02:59 PM
nonschlont's Avatar
[QUOTE=G20;6875551]My injectors scaling is set as 522. The latency values are
4.69 3.504
7.03 2.184
9.38 1.320
11.72 0.840
14.06 0.528
16.41 0.350
18.68 0.240
Page 1, post1. Try this, and report back.
Injectors Delfi? Prescision labeled injectors-780 cc.
Injector scailing :609!
Battery voltage Latency:
3.312
1.68
1.032
0.672
0.432
0.264
0.144
(stock)
No other tables touched .Stock-like idle.
Old Mar 30, 2009 | 03:00 PM
Jack_of_Trades's Avatar
Smoothing out your fuel map will greatly improve your consistency when accelerating from any RPM, not just a 3000-to-redline pull. If you overshoot your target boost somehow, you might have a dangerously lean condition above 4000rpm. Overboosting does happen to the best of us, better to prepare for such instances.
G20's Avatar
G20
Originally Posted by nonschlont
Its obvious, the injectors could be dialed in a lil better by the look of your fuel map. Like we have said, ur fuel map is all over the place. The values in your Fuel map are just values, not actuall AFR, but if you have the scaling/latencies dialed in, it should be very close to actuall AFR ~ -.5 difference.
The way you have it, it might give you the AFR in your logs that ur looking for, but the ecu has to do all kinds of work to keep it in range. Confirm what is in the injector scaling thread for your injectors, and maybe try that scaling/latency... not sure if your scaling/latencies from there...
And yes, you can tell if your scaling is off, just by the look of the map. It will look linear when your scaling and latencies are dialed in.
thanks! I got the global scale value = 522 and injectors latency values from an AEM table listed somewhere in Injectors Scale and Latencies thread somewhere on here. But I'll do more looking and improving it.
Old Mar 30, 2009 | 03:03 PM
G20's Avatar
G20
[QUOTE=nonschlont;6875852]
4.69 3.504
7.03 2.184
9.38 1.320
11.72 0.840
14.06 0.528
16.41 0.350
18.68 0.240
heres what I found w/ 30 secs. of searching. Page 1, post1. Try this, and report back.
3.312
1.68
1.032
0.672
0.432
0.264
0.144
(stock)
Good good! Will do but it'll take me some times as I'll have to reset the fuel map to retune the thing again. Should be no problem just need the times.
nonschlont's Avatar
Im sure you'll get it! GL take your time, and dial it in.
Old Mar 30, 2009 | 03:05 PM
G20's Avatar
G20
You're right. I did get overboost sometimes but thank god the boost cut kicked in. That's why I'm adjusted the boost cut table values carefully not put in large arbitrary numbers but used those that closely matched my ideal maximum load numbers.
Old Mar 30, 2009 | 03:11 PM
G20's Avatar
G20
Originally Posted by Early EVO
I have seen worse fuel tables!!!!!! If there was a comedy map section I would post a couple.
He'll get the his fuel sorted out with the suggestions others have made.
Hey! Thanks.
Old Apr 5, 2009 | 07:40 PM
G20's Avatar
G20
ok! i just spend the last few days rescale the injectors and the fuel completely. I'll like to thank "l2r88gst" and "MalibuJack" for their posts regarding injectors scaling and latency. Without reading their posts I'll probably fulling all my hair scaling the injectors.
Here is my fuel map. Hopefully it'll be "nicer" than the original on of this threat. I tuned to achieve the same boost and timings level (24 psi peak and 2-13+ timings advance). I noticed that the car is using less fuel now. That's good as it's my dd. Thank you for your suggestion that pushed me to "dig" deeper. Any more suggestion is welcome.
Please see attached the Evo Maptracer image and datalog file.
File Type: zip
Old Apr 5, 2009 | 07:43 PM
Wicked E's Avatar
Originally Posted by GST Motorsports
What the heck is going on with your fuel map?
I laughed so hard, I woke up the wife.
Old Apr 5, 2009 | 07:49 PM
G20's Avatar
G20
^ Why you laugh that hard? I've seen worse. I was taking the global scaling lightly hence the fuel map was out of place. So is the new one I posted above better now?
Old Apr 5, 2009 | 07:55 PM
Wicked E's Avatar
Question... Did you at all read the "How to tune" thread?? I suggest you do so, several times and take notes. Those fuel maps are awful... I cringe at the thought of a 4g63 with a hole in it...
-E
Old Apr 5, 2009 | 08:02 PM
rolly1818's Avatar
Registered User
dont worry about it bro. u will get it dialed in.
i think your logging too many things. you should reduce that to get more accurate data.
from looking at the pic above i am guessing ur using map tracer to identify the cells u hit. good, but when driving the conditions change (uphill/downhill, partial TPS, etc) u will hit other load cells and ur fuel is only tuned for WOT. i hope ur timing is not the same!
i am not on my "tuning PC" or i would put up my fuel map for you to see.
Old Apr 5, 2009 | 08:49 PM
G20's Avatar
G20
-E
So I see that you're the kind like to assume lowly about other people without knowing them. Thank for looking anyway but your comment does not help me much.
Question for you... Do you even look at my datalog, which is really matter, at all before thinking of I'll make a hole in my engine?
Old Apr 5, 2009 | 08:52 PM
G20's Avatar
G20
Thank man! I believe I got it dial in. The car is pulling great with good a/f and timing. Boost to 24 psi, no knock. LTFT great. All in 91 oct.
