Found Thermo Fan Switch Conditions
Old Sep 19, 2012 | 05:14 PM
  #91
Abacus's Avatar
My ROM (88590015 )does not have those tables, Where can I find them?
Originally Posted by killerpenguin21
no, im running them on a stock rom. merlins tuning guide has instructions, as well as a recommended "upgraded" table. thats what i followed.
Old Sep 19, 2012 | 05:54 PM
  #92
killerpenguin21's Avatar
your doing something wrong. im running them on a stock 88590015 rom
Old Oct 3, 2012 | 04:45 PM
  #93
Abacus's Avatar
Digging this thread up..
I installed V7 and was able to add the tables below. Since this post is almost a year old, are these the best tables to use now? I'm just trying to keep the a/c fan on more and then both fans on if I were to go to the track. Thanks in advance
Originally Posted by ug_orf
lets blow off the dust...
the v7 has the code lines for the fans when stationary
<table name="Thermo Fan Duty" category="Fan control" address="43d2" type="3D" level="2" swapxy="true" scaling="Percent (128)">
<table name="Conditions" type="Static X Axis" elements="3">
<data>Main Fan 0-22kph</data>
<data>A/C Fan 0-22kph</data>
<data>Main+A/C 0-22kph</data>
</table>
<table name="Engine Temp" address="513e" type="Y Axis" elements="12" scaling="Temp C"/>
</table>
now, about the tables for "moving", i've tweaked with the code lines and came up with this:
<table name="Thermo Fan Duty 2" category="Fan control" address="43d2" type="3D" swapxy="true" scaling="Percent (128)">
<table name="Conditions" type="Static X Axis" elements="9">
<data>Main Fan 20-50kph</data>
<data>Main Fan 50-80kph</data>
<data>Main Fan 80->>kph</data>
<data>A/C Fan 20-50kph</data>
<data>A/C Fan 50-80kph</data>
<data>A/C Fan 80->>kph</data>
<data>Main+A/C 20-50kph</data>
<data>Main+A/C 50-80kph</data>
<data>Main+A/C 80->>kph</data>
</table>
<table name="Engine Temp" address="57f2" type="Y Axis" elements="12" scaling="Temp C"/>
</table>
those this makes any sense?
look at the result.
Old Jan 4, 2013 | 02:57 PM
  #94
Oracle1's Avatar
Does anyone have the correct thermo fan definitions for 88570008?
I have somehow corrupted mine...
Old Aug 1, 2013 | 01:23 PM
  #95
SmurfZilla's Avatar
Digging this thread back up. Anyone know where i can add for 88590715. When i try the above xml add it only shows fan control as the section header but nothing else. I'd like to have my radiator fan on on high all the time and I would rather not wire the fan in directly if possible.
Old Aug 1, 2013 | 01:40 PM
  #96
thats a v7 rom isnt it? it should be in there. do you have your view set to developer? i can double check mine when i get home from work tonight.
Old Aug 2, 2013 | 06:22 AM
  #97
SmurfZilla's Avatar
I do but I didn't see it. What category is under? Its completely possible I missed it the MILLIONS of times I've looked over it?
Old Aug 2, 2013 | 07:10 AM
  #98
SmurfZilla's Avatar
Correction. I think I found it under ECU Periphery1 (FBA) bits. There is a bit.5 2nd thermo fan table, is this it?
Old Aug 2, 2013 | 08:54 AM
  #99
this is what i have:
my FBA bit is set to zero. theres a chance that i copied over xml into the tephra base file since i was running a few options on my stock rom though.
Old Aug 2, 2013 | 09:01 AM
  #100
SmurfZilla's Avatar
Under Misc I have Air Density Compensation for Load, Coolant temp scaling and IAT Scaling. And under Miscellaneous I see everything but the last 2 thermo entries.
Can you possible copy whats in that category xml and post so I can try to see if it will pop up in ECUFlash?
Old Aug 2, 2013 | 09:47 AM
  #101
i have the section i screen grabbed above, but i also have one titled "Misc" where i have the coolant temp/IAT scaling/Load tables you're seeing.
just looked through my base xml's for 20 minutes and i cant find the xml for the fan...im now very confused also lol.
when i did it tho, i definitely just added whatever is in this thread (or possibly whats on the tephra wiki page)
Old Aug 2, 2013 | 09:55 AM
  #102
SmurfZilla's Avatar
When I do that either it gives me an error parsing one of the lines of code or it just shows a category header of fan temp and nothing expandable underneath.
Old Aug 2, 2013 | 10:01 AM
  #103
SmurfZilla's Avatar
Yeah I don't really find anything beyond this thread thats even close to what I'm looking for.
Hell I don't even know if what I'm after is possible. I just want to essentially have the fan on high once it passes 160. just don't want to bypass the thermo control if at all possible. I hate hacking OEM wiring.
Old Aug 2, 2013 | 12:25 PM
  #104
ive gotta have the xml input somewhere...
what version of ecuflash are you using?
Old Aug 2, 2013 | 01:08 PM
  #105
211Ratsbud's Avatar
I'm not a guru but I restacked 8858 and for some if this stuff it's discussed in threads totally not related - hard to search for. Ill dig thru my short cuts later. I'm using this in 8858.
Maybe try swapping addresses or reference another rom XML for a different rom
