help me understand my logs ...
Old Apr 11, 2009 | 11:40 AM
voidhawk's Avatar
The data below is from a 2nd gear pull. There was no error correction on the boost curve (still tuning the WGDC base map), but I'm targeting 24lb.
I know I need to get rid of the knock, but here is what I'm confused about: I thought the way to avoid knock is by either pulling timing, or adding more fuel ... but ... from 5000 rpm to redline I'm running more timing, leaner AFR, and more load with zero knock, whereas from 2500-5000rpm I have much less timing, richer AFR and less load, but it's knocking like a crackwhore at a cheap motel door ... what gives?
Old Apr 11, 2009 | 12:29 PM
nothere's Avatar
depending on what gear you are in..
your pull is starting at really low rpm. no matter what the load is saying you are near lugging the motor. this puts too much pressure on the cylinder, let the optimum timing suffer at this stage to let the engine relax a little.
I don't even try max throttle below 3 grand, typical driving doesn't get you there and track driving won't either.
is (AFR map) your afr? if that is what it means, to much fuel.
try richening your spool up, and lower timing in the low load area a bit more. <150.
once knock has started it takes a lot more (lack of) energy to kill than if it never started.
I might be seeing it all wrong too.
Old Apr 11, 2009 | 04:54 PM
voidhawk's Avatar
hey - thanks for the feedback! Yeah it's a 2nd gear pull - I start them low since that way I get a longer curve which I thought would help with the tuning (the onramp I'm using is too short for a full 3rd gear pull). I'll try something closer to the real thing tonight when I can hit the back roads.
The AFR map is the value in the cell that the ECU is looking at (as I understand it), not the actual AFR (I don't have a wideband). I do track AFR using the O2 voltage though, which I've been told is pretty accurate.
Old Apr 11, 2009 | 05:20 PM
nothere's Avatar
I've never seen my afr map move, so I thought it was mislabeled. I thought it was an indication the ecu was going to blend in the low octane fuel map.
what logger is that?
Old Apr 11, 2009 | 05:43 PM
voidhawk's Avatar
That's EvoScan - it's just showing the value of whatever cell in the AFR map the ECU is currently using right?
Old Apr 11, 2009 | 08:07 PM
lemmonhead's Avatar
(timing low across the board)get rid of that negative timing and ya your a/f are to rich down low. ontop you need to add more timing still but you a/f are good uptop!
negative timing makes the combustion still happening during the exhuast stoke causing knock sensors to go crazy.
Old Apr 11, 2009 | 10:15 PM
voidhawk's Avatar
you speak truth wise one . I kept reducing timing thinking that would improve the knock when it actually was the cause of it ... starting to feel much better now. What timing should I aim for at redline? thx!
nj1266
Jan 25, 2026 01:43 AM
LiX
Lancer Engine Management / Tuning Forums
11
May 3, 2012 12:55 PM
voidhawk
Northwest Region
60
Apr 4, 2008 12:42 PM
nj1266
Jan 17, 2008 08:08 AM
voidhawk
Northwest Region
12
Mar 22, 2005 07:40 AM
